Long Tube Headers and true dual exhaust HELP
Old Jun 1, 2009 | 07:00 PM
ngonnelly's Avatar
Car: 1990 Camaro IROC-Z28
Engine: 5.7L 350cid
Transmission: auto
Axle/Gears: i think 3.42
i went to the town minkie mufflers to get my custom exhust priced they told me they told me they wouldnt do it beacuse iv got Long Tube Headers and idk want the hell to do now iv got headmen hedders from summit and the guy at minkie told me he cant to it un less cutes the fram or some thing like that so iv got two requests if any one know how to rout the pipes with full hedders let me know or pic would be nice or if youv got a pic of it all done id like to see and i live in nassau county new york so if any one knows of a good custum exhaust place let me know thanks
and sorry for spelling errors
Old Jun 1, 2009 | 07:16 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: Long Tube Headers and true dual exhaust HELP
https://www.thirdgen.org/forums/exha...l-exhaust.html
Old Jun 2, 2009 | 08:00 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
The guy you talked to is obviously a complete moron. At the most you will will need some hedman s bends to clear the tranny if your running an auto. After that you can route the exhaust anywhere you want. Also what mufflers do you plan on useing your space is limited.
Old Jun 2, 2009 | 11:54 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
The problem is that getting outside the trans tunnel requires going over the subframe rails at some point, and it destroys ground clearance, but really not as badly as having the header flanges hanging down. Long-tubes and duals are definately a challenge when trying to maximize ground clearance.
TA
Old Jun 2, 2009 | 01:11 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
whoever says it is impossible i did it with hedman 1 5/8" collector headers, mated to hedman S bends then used a Summit universal H-pipe kit, then 2 moroso spiral mufflers and 2 turn downs before the rearend. IT was an amazing upgrade to the y-pipe setup.
Old Jun 2, 2009 | 01:15 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I agree. I have the same setup less the H pipe and mine dump @ the rear tires.
Old Jun 2, 2009 | 05:52 PM
ngonnelly's Avatar
Engine: 5.7L 350cid
Transmission: auto
iv got big size tires in the back that shoud help with ground clearnce no?
Old Jun 2, 2009 | 07:07 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
i wanted to do somethign similar, just switch the h pipe to a x pipe. ill have to research though.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
beastin91rs
Oct 9, 2015 07:38 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
