Stock Cataytic Converter for 1989 TTA-Anything Special about it?
Old Jun 8, 2009 | 10:00 AM
ROBERTDMERRILL's Avatar
Hi,
Just looking for stock for my 89 TTA. Not sure if they are the same as regular TA or Camaros or if they are specific to TTA's/GN's.
Here is a Pic of one:
I also have a Flang thing:
Thanks,
Rob
Old Jun 8, 2009 | 10:24 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Stock Cataytic Converter for 1989 TTA-Anything Special about it?
all I know is that the stock converters are very restrictive
Old Jun 8, 2009 | 04:01 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Joe is correct. Most stock cats on our cars were very restrictive compared to modern aftermarket cats.
Old Jun 8, 2009 | 04:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check Jegs or Summit out for a stock DIRECT replacement Catco Cat....Should be under $200 for a high flow one.
Note: I did NOT say a Universal one size fits all.
Old Jun 8, 2009 | 05:20 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
all the new ones should be high flow. I have a catco on my car and works great!
Old Jun 8, 2009 | 05:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
im not a pro with this one, but that does not look like the cats the v8 cars used, it may be different.
i checked through summit, and the 3.8 tta was not an option for any of their cats.
Old Jun 8, 2009 | 05:35 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
The Hot setup is to run duals with Dynotech 2.5 inlet outlet Hi Po cats. This is the link to the 3 inchers which are the same only bigger. You don't need the 3 with duals.
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 8, 2009 | 05:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
funny that nobody cares that he is looking for a stock replacement.
Old Jun 8, 2009 | 06:39 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I think your right. Here is my stock cat from my 89 camaro. Just took pictures today.
Attached Thumbnails Stock Cataytic Converter for 1989 TTA-Anything Special about it?-dsc05398.jpg   Stock Cataytic Converter for 1989 TTA-Anything Special about it?-dsc05400.jpg
Old Jun 8, 2009 | 11:18 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
My 84z has the same exact cat, or rather did until yesterday. I think they were basically what the 80's Vettes used. Seems liek I read that somewhere before. not sure if it was an option. I could be wrong tho. Probably shitty none the less.
Old Jun 10, 2009 | 08:16 AM
Why is it funny that I am looking for a stock replacement? And why would anyone care?
Rob
Old Jun 10, 2009 | 10:28 AM
DJP87Z28's Avatar
Rob
I did not read that it was for a Turbo V6. I really do not think you are going to find the exact Cat. But knowning GM there may be nothing special about it. I would look for a Hi- flow one with about the same dimensions. Or is it time to replace your enitire exhaust system from engine back???
Old Jun 10, 2009 | 10:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Interesting. I've never seen one like it. The cross member is different, but I don't know if that would effect the cat.
Found a pic:
https://www.thirdgen.org/forums/atta...t-ttatrans.jpg
JamesC
Old Jun 10, 2009 | 10:37 AM
Stephen's Avatar
Car: 87 GTA
Rob
I don't think he's thinking its funny that you are wanting a stock replacement, but rather.......Funny that everyone pipes up with their recommendations about new cats or duals, instead of just answering your question.
My guess is, you are looking for a STOCK, OEM duplicate, to retain originality and/or show points, for a limited edition, TTA?
People seem to like to tell others what THEY think they should do, rather than just answering the persons question & letting the person do their own car, their way.
Old Jun 10, 2009 | 11:22 AM
JamesC's Avatar
A stock cat on an HO model would have had a four-bolt flange on both ends.
JamesC
jaridjohn
Jul 8, 2024 03:49 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Derick15
Sep 17, 2016 05:28 PM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
