LS1 Headers On A 3rd Gen?
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hello there everyone quick question, would ls1 headers fit a tpi motor by any chance?
thanks, Tony
thanks, Tony
Engine: 3.0L 2JZGE
Re: LS1 Headers On A 3rd Gen?
Is it cause of the way the ports are or so? cause i could get a set of long tube pacesetters for $50
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Nope... You'd have found that if you had used the
Car: 1989 Trans Am
Engine: 355 HSR
Port design differences... SBC (TPI) motors have the two center exhaust ports together (siamesed) and LS1s have equidistant exhaust ports (all are the same distance apart...)
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
And thats just the tip of the iceberg as to why they dont fit.
Lots of info in the LSx section...
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Not even a chance to make them work. Have a better chance of Fox body headers fitting (LOL)...
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
These guys are right, they have nothing in common with TPI engines, centers, port shapes, spacing, port height and even the subframe shape are very different.
TA
TA
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Look at the headers then look at your exhaust ports. You gotta walk before you can run.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
