Header bolt question..Yes I searched..
Car: 1989 GTA
I have a set of slp tri y headers and need a set of bolts to hook it up to the engine. The only problem is that on each header, two of the bolts holes have lips raised like 3/4". Anyone know what to do or where to get a set? Thanks
Car: 1989 Formula
Engine: LO3
Axle/Gears: 2.73 -> 3.27 9 Bolt
Re: Header bolt question..Yes I searched..
I'm not 100% certain I know what you mean, but it may possibly be so you can use the stock alternator and a/c compressor support bracket?
Car: 1990
Axle/Gears: stock
did you look on summit? but be sure to post the answer if you find out before someone tells you.
good luck.
tony
good luck.
tony
Car: 1989 GTA
well, not 100% sure yet, but a friend said I am supposed to use the studs for brackets in these locations. Still, if anyone knows more please help, Thanks!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
V-belt or serp?
JamesC
JamesC
My serp set-up requires two spacers for proper fitment (see the link below for pics). Perhaps SLP has simply built the spacer into the header. If the latter is the case, you'd simply need longer bolts. I 'believe' the following is correct: Pass side 3/8-16 x 3.25 and driver's side 3/8-16 x 2.75
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
JamesC
Car: 1989 GTA
Those are the headers, they are at my guy's shop now so pics couldn't be had quickly, but I had these. The bolt holes with the extended tubes can be seen on the header on the left, above the third tube from the bottom. You can see one on the right header just above the third tube from the bottom. Thanks for all the replies so far!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
your not going to find a set of bolts with a couple longer ones. Measure the extension tubes and buy long bolts as needed. Allen head will work best because of the lack of clearance to the header tube. Use regular 3/8x1 bolts for the rest, again, a 12pt or allen head would be best
Car: 1989 GTA
I bought stage 8 locking header bolts that are 3/8-16X3/4". Will they work on the other bolts or do I need the 1" bolts? Thanks for the help!
Car: 86 Trans Am
i have slp's other headers, and they have a 3/8 flange, not sure what your have, but its most like the same. 3/4 bolts are not long enough. They only leave 3/8" past the flange, then once the header gasket is there, your left with 1/4", not enough thread. You will need 1" if they have 3/8 flanges.
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I have SLP headers on my 90 TPI, on the forward drivers' side, the raised "tube" is to provide a standoff for an alternator support bracket that goes to the back of the alternator. uses the double-ended hex stud.
on the passenger side, i recollect the fwd middle one was for an AC compressor bracket support.
I had the same issue you're having with MY slp headers. ...I ended up simply buying (as stated earlier) longer allen head bolts, and THEN using a lock washer.
....I've never had issues with those bolts backing out.
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Dialed_In
Aug 20, 2015 01:45 PM
