Flowmaster Dual exhaust
Car: 1988 Camaro IROCZ
Axle/Gears: Stock
hi i have a 87 IROCZ and i would like to get a dual exhaust. i found a dual exhaust kit by Flowmaster on www.horsepowerfreaks.com and i was wondering if i would be able to put it in my car. i also dont know how much ground clearance i would get bc it has a H-pipe. can i put an H-pipe on a 3rd gen? and also my friend said that i can take the cat off of my car when it is 21 years old, and its 22 years old. thanks for the help.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Flowmaster Dual exhaust
The link is to the main page not to the exhasut you want. To my knowledge no one makes a true dual exhaust for our cars. You can fab one but ground clearance is usally an issue. And no matter how old you car is your not suppose to take your cats off the car. Some people do it and get away with it, like myself but your not suppose to do it. In NY its anything 25 model years and older is emissions exempt.
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
Dynomax makes a dual kit for our cars.....
http://www.summitracing.com/parts/WLK-89009/
Mufflers are not included and its 2.25 id, good luck passing a sniffer
Car: 1984 z28
Engine: 355
Axle/Gears: Stock
http://www.horsepowerfreaks.com/part...Rear_Exit/9948
the exhaust system should be in this link. its the 5th one down from the top of the list
Car: 1984 z28
Engine: 355
Looks good, just dosnt say if its for long tube headers or the stock shortys. Also make sure what size cat you have before buying the exhaust.
Axle/Gears: Stock
yea, i think i have 3'' flanged cat, in the reviews somebody purchased the exhaust system that had a 88 camaro. i wish i was able to get a hold of him so i could ask him some questions. u think i would have to purchase another cat then, like i said before my friend said that i can take it off after 21 years and i would have to get a safety inspection
Car: 1984 z28
Engine: 355
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I would double check what exactly you're interested in. On HPF's website it says that it uses the stock style 80 series crossflow muffler. That is NOT what is pictured.
Axle/Gears: Stock
Wat do u mean by stock style 80 crossflow mufflers, and I'm interested in the dual exhaust on the website. Does it matter wat muffler is use on the dual exhaust kit
Car: 1984 z28
Engine: 355
He means stock as in one pipe in two tail pipes out. Only one muffler is used on stock camaros and trans ams.I dont know what pic he is looking at but the mufflers at the top of that website are not 80 series mufflers.
Car: 1984 z28
Engine: 355
I took a 2nd look at the website and bdltke is right. The flowmaster sytem they are offering is the same as everyone elses system. Its just a stock replacement and isnt a true dual.
Axle/Gears: Stock
okay thanks for the help. u wouldnt happen to know of any manufacturers that make a true dual. because i dont have the money to have someone fab up one and i definately cant fab up one myself.
Car: 87 GTA
After the 25yr mark (23 here in TX), it only means you are exempt FROM THE TESTING. Not that you are allowed to remove the emissions parts. The tests are only a state requirement. That the stuff be on the car, is Federal. They still have to be there, you simply are not tested, as to how effective they are.
Dynomax makes a 50-state legal dual exhaust system, but requires that the car have the original dual cat system, to actually be legal. Not saying it is a good system (2.5" & crimp bends, not mandrel bends), ,but it does exist. Look on the Summit site for it.
Axle/Gears: Stock
okay thanks but i think im just going to stick with the stock exhaust system. thanks for all the help guys
Car: 89 RS
Engine: 355
Transmission: T5 B&M Shift kit with short throw
Axle/Gears: 3.73 Posi
I had my true dual set up done for under 250.00. http://s794.photobucket.com/albums/yy226/cvz6977/
Car: 1984 Z/28 Camaro
Engine: 406 SBC
Transmission: T56 6spd. Tremec
Axle/Gears: 3.23 4 wheel disc brakes
if your looking for true duals the best way is the way that I'm going to run mine get the oval exhaust pipe they make a H pipe that goes from round to oval then get two pieces about 3' long for each side and the adapters to go back to round pipe then go up over the axle like the dual cat cars do and goes into two mufflers and two 3" tail pipes. Look on ebay they have a dual cat back system. You could hook back onto them just to come up over rear and out the back. It may take a small amount of fabricating but you can make a true dual exhaust 3rd gen Camaro with out too many hassles. I would only suggest going through all that work if you have a motor that needs to breathe. If you motor isn't putting out over 450 hp just get high flow cat and good hi flow cat back system with 3" in and 3" out they have them on ebay too.
I love the sound of flowmasters exhaust and I just purchased the flowmasters 80 series exhaust that's three inch tubing and 3 inch dual tip stainless steel (polished) tips. I can't wait to get it put on. How much you think a shop would chafes me to weld it all up? Anyone have a guess.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
