Notching the frame rails for exhuast
Old Dec 6, 2009 | 11:24 PM
355sbc's Avatar
Car: 1989 camaro
Engine: 350 sbc
Transmission: 9" tail th350 B&M stage 2 shift kit
Axle/Gears: 4.10
Tell me what you guys think of cutting up into the frame rails like 2" by the trans
then boxing it in with 1/8" mild steel plates and connecting the sub-frame connectors to the plates. The 6pt cage will also be tied into the sfc.
Old Dec 6, 2009 | 11:50 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
Re: Notching the frame rails for exhuast
ive been thinking of the exact same thing, ive got the stainless works headers and clearance is tight, especially w/ the spohn crossmember.
where exactly did you want cut?
Old Dec 7, 2009 | 12:10 AM
Stephen's Avatar
Car: 87 GTA
With SFCs, a cage & boxing it all back in, you'll likely be OK, if you don't cut TOO MUCH out. I know at least one guy here on TGO, notched his where they turn inwards for clearance off the exhaust coming off the long tube headers.
Where were you planning on cutting?
Old Dec 7, 2009 | 12:29 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
ive always wanted to see somebody do it the way i been thinkin. if your gonna put an exhaust in and your worried bout clearance (all of us!) then why not rip the interior out, and cut out where the ehaust will run. okay hear me out, say you wanna 3 inch exhaust and your car is already lowered. figure out where you want to run your exhaust, get some 3.5" ID tubing and cut 12" lenghts at a time to insure you dont buckle your car. cut the 3.5" tubing right down the middle and weld it in. then run your 3" od exhaust in those tunnels. i wouldnt do it unless i put in a cage or at least 8 point roll bar,but youd only have bout 1.5" hanging below the car.
im doing it to my car someday after i drop this new motor in with full length headers.
Old Dec 8, 2009 | 05:58 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
i did it to my car and i have a 600hp 383sbc with no problems. exhaust tucks up in very nice.
Old Dec 8, 2009 | 06:12 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
^^^ would u happen to have any pics!!!
Thanks!!!
Old Dec 9, 2009 | 08:30 AM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
I could possibley get some. My car is in storage right now. I'll try.
Old Dec 9, 2009 | 04:01 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Look up my Ed Quay header install in the exhaust section. I cut out the original trans mount and built a double hump x member to fit true dual exhaust with no bends. The thread has pics also. Since then, I have redesigned my whole configuration. I used round tubing now and connected off the subframe to the rear seat pans for the trans x member mounting.
https://www.thirdgen.org/forums/exha...uay-1-7-a.html
Old Dec 9, 2009 | 08:49 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
thanks 1 badrz28, thats alot of fabbing. i dont have access to a welder, or i would jump on this. i hope kens86 can post some pics for some ideas
thanks
gixxer92
May 18, 2017 11:20 AM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
bplessy
Sep 30, 2015 12:14 PM
