tips for removing rusted pipes
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
ok i need to put on my new muffler but my exhuast pipes are rusted to the muffler and what do i do to get the pipes off without using a saw or heat. should i use a chiesle. i know it might dent up the pipes but i would be getting a magnaflow sometime later so it isnt a biggy if its small dents in the pipe thanks. sorry im typing with a cast on my arm.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: tips for removing rusted pipes
Penetrating oil, a chisel and BFHammer, and some one w/ two working arms! If you can cut a slit in the larger pipe on muffler and peel it back w/ hammer and chisel , keep oiling it...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You might be able to rent/borrow a removal tool. It's basically two pipe clamps and a threaded rod inbetween to extert a pushing force to push the pipe/muffler off.
Almost like this;
http://www.summitracing.com/parts/SUM-900652/
Almost like this;
Engine: 305TPI
thanks and i forgot to mention i already have the driver side pipe of while trying to remove before it cracked as started dragging so i just pulled the rest of the pipe of along with the sleeve that's still stuck on the pipe. and i noticed that the pipe runs THRU the muffler so if i can get the muffler off and the new 1 on will i be fine with just clamping it in the sleeve or will i need the 2 pipes welded back together. i can get pics if its unclear sounding.
Engine: 305TPI
Almost like this;
Almost like this;
Car: 89 z
Engine: Chevy 383
Axle/Gears: 9 bolt 3.73
you could use this
http://www.amazon.com/Danaher-Tool-K.../dp/B000M93OUM
I use em in the junkyards where there's no electricity. Doesn't cut like butter, more like wood. It's like a chainsaw blade but works like a plumbers tubing cutter with a lot more cutting blades.
hectre13
Sep 8, 2015 03:38 PM
