Need help figuring out what headers to run
Old Oct 5, 2010 | 06:52 AM
jtlockwood88's Avatar
Car: 88 Formula 350 / 87 Iroc 68k miles
Engine: 355 / 355
Transmission: 700r4 / 700r4
Axle/Gears: 10bolt w/3.23 - 9bolt w/3.27
hey guys im looking to hear some opinions and help me figure out what headers i should run, well first off the car is pretty much stock at this point, but i do have a lot of plans for it in the future so keep that in mind. well for starters i think im gonna go with shorty headers but i would really like to run Hooker S/C Long Tube Headers with a mufflex y-pipe. also one point to add is that i am not running and of the emissions equipment. so any input would be greatly appriciated, hope this will help me firgure out which direction i will go
Old Oct 5, 2010 | 04:15 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Need help figuring out what headers to run
The hooker super comp full length headers on a stock motor will suck big time. You will lose a ton of low end power cause there 1-3/4. Stick with a shorty header in the 1-5/8 range and you will be ok. Hooker actually makes a super comp shorty in 1-5/8 with a y pipe I believe. So all you would have to do is pickup a cat back of your choice and you will be good to go.
Old Oct 5, 2010 | 09:38 PM
Engine: 355 / 355
alright sounds good, so any suggestions on a good set of shorty headers that come with a y-pipe with out the A.I.R. stuff on it? or if they dont come with a y-pipe will the stock one fit on it?
Old Oct 6, 2010 | 07:48 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
If you stay with a good brand like hooker,edelbrock,or hedman you cant go wrong. Just check out what you can get for the best bang for your buck. And for a cat back make sure there a good exhaust size and listen to some sound clips of the muffler the provide so you know what its gonna sound like when you install it.
Old Oct 6, 2010 | 11:22 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Go with Dyno Dons 1 3/4in shorty headers with y-pipe. These headers are the only headers you can get that are 1 3/4in. Plus they will work even better for future mods. All other headers are bullshit because you will have spark plug and plug wires boot insulation problems. His headers eliminated those problems.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
