headers? got a set and a lil clueless now..
Old Jan 4, 2011 | 06:17 PM
Blue1990camaro's Avatar
ok so its a 85 IROC Z 305 TPI, well im new to this computerized crap lol i prefer carb but anyway i got a really nice set of shorty headers brand new, now my car has a smog pump and o2 sensors, my headers dont have provisions for either of these, so, wat if i just took off the smog pump and o2 sensors, would it have any effect on how it runs since its TPI other then the SES light on?
i cn get pics of the car n headers if anyone wana see lol
Old Jan 5, 2011 | 09:56 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: headers? got a set and a lil clueless now..
You can run fine without the air pump.
You cannot run fine without a functioning O2 sensor unless you get a custom tuned PROM for open-loop operation only.
You can easily get weld-in O2 bungs on ebay, then put the O2 sensor into the collector area of one of your headers.
Old Jan 6, 2011 | 03:15 PM
my drivers side headers has the bung for n o2 sensor but its just welded on, it so u have teh option to burn the hole open or run without it
so if i remeove the smog pump i wont have a SES light and it wont run right? as long as i have the o2 sensor on?
Old Jan 6, 2011 | 05:55 PM
torque_is_good's Avatar
smog pump aka AIR removed your car will be fine
O2 sensors removed and your car will run terrible and throw codes
so, keep the O2's.
Old Jan 7, 2011 | 02:32 PM
ok kool, but it wont throw a "rich mixture" code?
Old Jan 7, 2011 | 03:03 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Not from the smog pump being removed, no. The smog pump pumps air (hence the fancy acronym) into the catalytic converter to help burn off any left over fuel. Since the only O2 sensors are before the cat, the ECM never knows if this works or not so it won't throw any "rich" or "lean" codes. On a newer OBD2 car with O2 sensors both upstream and downstream from the cat, you wouldn't be able to remove the smog pump without it throwing a code.
Old Jan 7, 2011 | 03:07 PM
ahh ok, so now i gta take the drivers header over to teh shop and burn the hole threw, it came with a bung on the drivers side, tehy r for n 85 camaro which is what i have so im assuming mine has only one, but the bung is welded on but the hold isnt in the pipe
Old Jan 7, 2011 | 03:36 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
You can burn it or drill it. I'm pretty sure a 1/2" drill bit will work. I can't remember what size I used when I did mine.
Old Jan 7, 2011 | 03:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Careful when you drill it or cut it. If you screw up the threads by hitting them or getting it too hot, youll need to weld a new bung on.
Old Jan 11, 2011 | 03:07 PM
thats what im worried about
Old Jan 11, 2011 | 04:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Ive drilled that hole out a few times. Its not that hard. Just hold the drill straight. I'm pretty sure I use a 5/8" drill though. I think 1/2" is a little small. If you do bung up the threads, an 18mm spark plug thread chaser will work to clean them up.
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
bamaboy0323
Sep 3, 2015 06:07 AM
LilHot
Aug 23, 2015 09:36 PM
