Trying to locate a muffler/pls help
Old Feb 7, 2011 | 03:20 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
I have the flowmaster 3inch cat back, i sold the muffler because i hate flowmasters. Am looking for a single in single out. Cant seem to find one that looks like a stock muffler routing. Only thing i can think of is this
http://www.summitracing.com/parts/MPE-14419/?rtype=10 which am not positive it will work. Any help is appreciated.
Someone posted a similiar question on another post but noone really came up with an answer. If i cant go with a magnaflow then i would need something with the same performance. Please dont even mention flowmasters, its not an option :P
Single stock looking tip is my goal
Old Feb 7, 2011 | 03:28 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Trying to locate a muffler/pls help
Stock was a single-in, dual-out on these cars. That's why you can't find a stock single-in/out.
That muffler you linked will work, if you can make your own tailpipe and hangers. Just mount it sideways under the rear, behind the gas tank.
Old Feb 7, 2011 | 03:31 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Stock I ment the box looking style, like how the flows look. I know its dual out I just prefer the single outlet. Tired of have the fake dual look
Old Feb 7, 2011 | 04:19 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
You could always go with true duals?
As for the wider oval-shaped mufflers, there aren't a lot of performance ones out there. You could try Thrush, Dynomax, or Cherry Bomb. They all make that shape muffler in a single-in/out configuration that should fit.
I don't think Magnaflow does though.
Old Feb 7, 2011 | 05:48 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Noone makes a muffler like flowmaster with 1 in 1 out though? Not keen on the oval shape either lol
What about if I plug a hole on the dual outlets? Will that mess if flow of the muffler? Cherry bombs is out of the question. I need to tame the exhaust note alottle without damaging performance
Old Feb 7, 2011 | 08:55 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
http://www.flowmastermufflers.com/sh...e=&orig=842441
Any known good performace mufflers with this design? Again, not out for the noise, rather best performing single outlet.
Worst comes to worse ill have to buy the dual outlets if not, but trying my hardest to not go that route.
True duals is out of the question. Am running a 700r4, i would have went with custom true dual if i went the t-56 route, but didnt unfortunatly and need to work with what i got. Mufflex only has 4inch inlets on there mufflers right? so am sure thats out of the question too, but thats pretty much what am looking for with style wise
Old Feb 7, 2011 | 09:07 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
When I suggested Cherry Bombs, I wasn't referring to their glasspacks. They make a muffler just like that Flowmaster one you linked in the last post.
These:
http://www.summitracing.com/parts/IMM-7426/
Or these:
http://www.summitracing.com/parts/IMM-16806/
Here the others I was able to find:
Dynomax version:
http://www.summitracing.com/search/Part-Type/Mufflers/Brand/Dynomax-Performance/Case-Shape/Oval/Inlet-Quantity/One/Outlet-Quantity/One/Internal-Construction/Turbo-style/?Ns=Rank|Asc
Borlas:
http://www.summitracing.com/search/Part-Type/Mufflers/Case-Shape/Oval/Inlet-Quantity/One/Outlet-Quantity/One/Internal-Construction/Turbo-style/Brand/Borla/?Ns=Rank|Asc
Hooker:
http://www.summitracing.com/search/Part-Type/Mufflers/Case-Shape/Oval/Inlet-Quantity/One/Outlet-Quantity/One/Internal-Construction/Turbo-style/Brand/Hooker-Headers/?Ns=Rank|Asc
Old Feb 8, 2011 | 09:17 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
You think the cherry bomb or hooker muffler performs. As well as the magnaflow. Or am I stuck with dual outlets? Like I mentioned with my cam am trying to tame the exhaust without losing performance. Cherry bomb am receding to the silver one
Old Feb 8, 2011 | 04:41 PM
crackitoff's Avatar
Engine: Shafiroff 434
Transmission: Jake's Performance Stage 4 TH400
Axle/Gears: Strange S60/spool w/ 3.73's
what's up guys? i have a 3 inch magnaflow on my car with single in single out offset on both sides. bolts up to the over axle pipe with no problems. looks nice to...polished stainless steel. i called mufflex perf. in jersey and they made me a hide-a-way tailpipe for $53.70 shipped. i got the muffler from automotive concepts in pennsylvania for about $86 shipped. their part number for the muffler is #14239. you might have to elongate the d side tailpipe tab where the bolt goes through to mount it. other than that it fits and looks perfect. sorry i don't have any pictures yet but trust me..it will work.
ern
Old Feb 8, 2011 | 04:47 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
the muffler type is a "crossflow" there is PLENTY of aftermarket ones out there
Old Feb 8, 2011 | 04:49 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Ha, while you were typing that i was on jegs. Before i even thought about looking at jegs mufflers i asked here. Seems Jegs has alot more selection then summit.
Now its a toss up... what you mentioned
http://www.jegs.com/i/Magnaflow/642/14239/10002/-1
or a dynomax ultra-flo SS
http://www.jegs.com/p/Dynomax/Dynoma...44882/10002/-1
If i could only find a flow chart
Old Feb 8, 2011 | 04:50 PM
crackitoff's Avatar
i think you'll like the sound of the magnaflow better.
ern
Old Feb 8, 2011 | 05:36 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
more of a performance then sound. My whole motor was based on producing numbers, not based on how nice i can make it sound Dynomax said theres are 1132cfm, any clue what magna's are?
heres acouple pics if your interested in the build. most pics are page 2 and 3
https://www.thirdgen.org/forums/engi...-383-swap.html
Lbibb
May 5, 2016 12:00 AM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
