Hedman Header 68470 Help!
Old Jun 23, 2011 | 08:52 PM
jetblacknewyear's Avatar
Car: 1987 Camario Iroc Z-28
I am installing the Hedman headers, and in the "Sticky" it says that these headers should fit my car. It's the stock 350 block with AFR 195cc heads on it if that helps.
My header on the passenger side is perfect. The drivers side hits the subframe, near the oil pan. It's the ring with the three holes in it to connect it to the Y pipe that hits.
I know these should fit, but why aren't they? The only thing I can think of is the motor mounts may be old, but would that really free up like an inch of room that I need?
I have all the header bolts in, but this ring around the collector is just right against the subframe.
Anything will help, thanks!
Old Jun 23, 2011 | 09:48 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Hedman Header 68470 Help!
My 68470's fit great. I'm guessing that your motor mounts are bad or the AFR heads are that much different. Also I think your talking about the crossmember not the subframe that the header is hitting, Right? I just looked under mine and there is about a 1/4 between the header and crossmember so there is not much room for error.
Mark.
Old Jun 23, 2011 | 10:26 PM
Sorry, yes, I meat the cross member.
Would a motor mount shrink that bad that it would close the gap like that?
It just took me a few hours to get that stupid engine in - I don't want to tear it out again.
Old Jun 23, 2011 | 10:54 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Rubber loses its elasticity. Think of rubber motor mounts like a worn out spring.
You can see the deformity in this pic
Old Jun 23, 2011 | 11:15 PM
Just thinking of taking the engine out again makes me shiver.
I'll try the motor mounts first I guess. The angle of the heads would be the only other thing, but I think AFR would make a standard angle for the side of the heads that accommodate everything.
Old Jun 24, 2011 | 09:45 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
it's not the motor mounts, i had the same problem with my coated ones, i called them up and they told me it was my world product heads, anyhow i took a grinder and notched the collector ring out, of course this voids the warranty.
and i have new poly motor mounts..
Old Jun 24, 2011 | 10:03 AM
Well, the new motor mounts are $24, so I will try those first, just in case.
I was actually laying underneath the car last night with a file just seeing if I could file off some of the header without taking it out of the car. I didn't want to disconnect the steering assembly again to get the header out.
I will try the mounts as they are over 20 years old, and then if that fails I'll grind down the collector ring, which was my first thought any way.
Funny thing while I'm mentioning having no room - when I put the engine back in the car it sat an inch or so lower than the transmission. I thought it was weird but got it lined up after a while. It makes sense that the mounts are old and have shrunk - so this may help the alignment of that as well.
Old Jun 24, 2011 | 11:46 PM
I replaced the motor mounts today (that sucked!) with brand spankin new ones and it didn't make any difference.
Guess I got to start grinding away at the collector ring.
Old Jun 25, 2011 | 01:59 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my question is, why are you running shorty headers on an engine that has afr 195's on it? seems you should be looking at a set of hooker longtubes or the like....
Old Jun 25, 2011 | 06:35 AM
I figured anything would breathe better than the stock crap, and didn't know if I'd have enough room for longtubes.
The list of what fits seems to be all shorty headers. IS there a set of longtubes that fits the car without any mods? And is there a y-pipe to go with that?
Old Jun 25, 2011 | 12:12 PM
mw66nova's Avatar
Engine: 7.0L
do some searching for hooker 2210's on here and elsewhere. lots of info on them
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
