How to put a muffler on with this setup
Old Jul 9, 2011 | 05:34 PM
83TransAmDayton's Avatar
Car: 83 trans am Dayton
Engine: 305 cross fire
Anyone have this rear Set up on there car and can post pictures to show me how you put a muffler on ? I wanna put on the
Flowmaster 80 Series Crossflow Muffler
Attached Thumbnails How to put a muffler on  with this setup-p1010003.jpg   How to put a muffler on  with this setup-p1010005.jpg   How to put a muffler on  with this setup-p1010002.jpg
Old Jul 9, 2011 | 05:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to put a muffler on with this setup
You'd just cut it all off and replace it.
Old Jul 10, 2011 | 12:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That factory dual muffler setup was pretty sad.
A complete cat-back is in order.
Old Jul 11, 2011 | 12:57 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
that came from the factory?
Old Jul 11, 2011 | 01:47 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Yup, that is completely factory...
Only way to run that muffler is if you get a single cat-back tube, the one you have now splits into two over the axle and wont work. might as well just get a whole cat-back but if your on a budget then pull a single cat-back tube off another thirdgen that has that then you can use the muffler you posted.
Old Aug 9, 2011 | 09:45 PM
DizzTransAm's Avatar
Car: '83 & '84 T/As
I had a Flow 80 put on, I got it from the junkyard and had it cut before the axel, this set up is really sad...
Old Aug 9, 2011 | 10:08 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Horrible, pre-school engineering there.
Old Aug 9, 2011 | 10:19 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Take it off without cutting it up just for easy removal, sell it to somebody trying to restore an early 3rd gen & get you a good catback. My complete mandrel bent 3" catback was like $220, IIRC.
Orr89RocZ
Apr 25, 2016 08:28 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
86White_T/A305
Aug 17, 2015 12:16 AM
gta power
Aug 13, 2015 06:15 AM
