T56 in 91, full length headers clear?
Old Jul 19, 2011 | 03:09 PM
BOSTONCAMARO's Avatar
Hello,
My friend and I are about to drop a 383 carbureted, Weiand street blower with the Quicktime Scattershield into his 91 Trans Am.
I have a few questions.
1. has anyone done this swap and used full length headers? if so, what brand and what is the price range.
2. anyone running true duals in one of these cars or is it simply not worth it?
3. anyone run exhaust under the car, but near the rockers with dumps before the rear wheels? if so any pics?
the motor is quite healthy, small blower, dart iron eagle 205 valve heads etc
Thanks in advance for your responses!
Tim
Lynn MA
Old Jul 19, 2011 | 03:58 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: T56 in 91, full length headers clear?
https://www.thirdgen.org/forums/exha...drel-bent.html
Old Jul 20, 2011 | 10:24 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Just to add a little to robguitargod1's link.. Depending what transmission crossmember you use you may not be able to do what he did. The Spohn crossmember definitely won't work for that, I have one in my car and the transmission mount goes straight across the area you'd want to run your exhaust. I kept the spohn crossmember though because I wanted the crossmember mounted torque arm and went with shorty headers instead, for me it was the easiest way to keep some ground clearance. Hawks makes a crossmember to clear the exhaust, or you can make one yourself. Skulte used to make one but they're next to impossible to find anymore.
Old Jul 20, 2011 | 10:26 AM
Car: '91 LS6/T56/9"
Engine: LS6
He's right, I'm using a hawks T56 crossmember. It's recessed for duals.
Old Jul 20, 2011 | 11:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I just bought one of those for the simple reason I want to run LTs. I had a spohn before.
Old Jul 20, 2011 | 03:39 PM
So you think the Hawk's is the way to go? I do know he was looking at both, we are more concerned about long tube header clearance, rather than the duals, the duals would be a project that would come later...so for now, would be nice to throw long tubes in, fab up a y pipe to a single 3 inch.
Old Jul 20, 2011 | 03:41 PM
Does the Hawk's crossmember come with a mount, a way to mount the torque arm? also what does the Hawk's crossmember go for?
Old Jul 20, 2011 | 03:43 PM
$110
It doesn't have a TQ arm mount.
Old Jul 20, 2011 | 03:48 PM
Anyone come up with a solution to use, make a torque arm mount with the Hawks? I have been out of third generation cars for a long time, my friend had one years ago and recently got this TA to do his swap in. Here is my 85. I went 12.50's with it on the motor, basic home built street motor.
I built it when I was 19, I am 37 now,,,,jeesh! I sold it when I was 25, then when I was 31, 32 bought it back from the person who literally drove it for 4 months then let it sit, at times in water a third of the way up the door, it was completely rotted but I got it home, get it running, stripped it and now put the motor in a 69 Corvette
Old Jul 22, 2011 | 04:03 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
https://www.thirdgen.org/forums/fabr...hn-torque.html
Old Jul 22, 2011 | 04:45 PM
If you are going to do that, don't even bother with the Hawks X-member. The reason to go with the Hawks X-member is to tuck the exhaust up tighter.
He just removed all of the extra clearance he got with it.
Old Jul 23, 2011 | 01:55 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I had hooker super comps for a third gen with the spohn trans cross member I had a custom exhaust put it and it wasnt an issue at all everything cleared fine and sounded great
Old Jul 28, 2011 | 06:29 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
As long as you dont use a spohn crossmember you should be fine. Seems like every car on here that has spohn parts is lowered, and they use a spohn crossmember, and their exhaust is god awful because of it.
This is my setup, been copied by a few since I got mine. Dual 2.5's into a single 3.5 then over the axle:
Key is to get a notched crossmember. There's so much room around a T56 to do it so if you can fab up an exhaust I bet you can make a decent crossmember while you're at it instead of using that Spohn stuff.
AussiePr0nCar
Mar 6, 2020 04:04 PM
evilstuie
Feb 28, 2016 03:33 PM
86iroc z Z28
Aug 21, 2015 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
