Is 3" overkill on a mildly worked L98?
Old Aug 8, 2011 | 08:32 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Is 3" overkill on a L98 that has a mild cam and a ported intake with slp runners?
What shortie headers and exhaust setup would be best? Are the subframe connectors i have in there gonna make replacing the exhaust a pain in the ***?
Old Aug 8, 2011 | 08:47 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Is 3" overkill on a mildly worked L98?
3" singe? Not at all I would go
3" true dual most likely yes.
I am using a 4" kit on my mildy worked 355. Cammed, Decked, single plane intake, KB Pistons, Rods, ported 882 heads. I love it.
Old Aug 8, 2011 | 08:50 PM
insomniac's Avatar
Engine: 5.7 L98
shortie headers into a y pipe to a single high flow cat to a intermediate pipe to flowmaster to 2 outlets...
where can i find a 3" y pipe that will bolt right up to shortie headers?
Old Aug 8, 2011 | 09:02 PM
Car: 1985 IROC-Z
Engine: 355
You cant you have to custom make one. Or do 2.5" into a 3" pipe. Nothing wrong with that.
Old Aug 8, 2011 | 09:14 PM
Spike_Akers's Avatar
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
the size of your exhaust is more dependent on your header size. 1 5/8 primaries should be enough, you'd always like to stay alittle smaller than be too large or you'll lose torque without gaining anything on the top end.. and for the rest of the exhaust 3" shouldnt be a problem at all
and its definitely easier to do the duals vs. fabbing a y pipe
Old Aug 9, 2011 | 05:43 AM
insomniac's Avatar
Engine: 5.7 L98
2.5 at the headers or at the cat? if at the cat do you goota go 2.5 the rest of the way then?
Old Aug 9, 2011 | 07:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The stickies at the top of the page may provide some ideas.
JamesC
Old Aug 9, 2011 | 07:18 AM
Shadow Z's Avatar
Car: Lots of 'em
Why shorty headers?
Old Aug 9, 2011 | 07:23 AM
insomniac's Avatar
Engine: 5.7 L98
Originally Posted by Shadow Z
Why shorty headers?
figured will fit better and wont have to worry about fabing a y pipe
Old Aug 9, 2011 | 07:32 AM
Shadow Z's Avatar
Car: Lots of 'em
I was the same way with the Mustang since it's a full time street car, figured shorty headers would be less of a pain. Gonna eventually pick up Stainless Works long tubes and catted X with deleted tubes. Cats just for inspection, offroad X any other time like always.
Check these things out.
No fabbing there, but it's expensive for their full stainless steel headers and Y pipe. I think around $1,300.
This is the setup I want for the Mustang. $1,609 for it with cats, like another $45 for their cat delete tubes. Only want the cats to pass inspection.
Old Aug 9, 2011 | 07:34 AM
Shadow Z's Avatar
Car: Lots of 'em
Scratch that, just realized that Y pipe from them is for stock manifolds.
Old Aug 9, 2011 | 08:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Most shorty header kits have a matching ypipe. Hooker 2055's have one but have 1.9-2.0" collectors on the header. Its a ball flange so the ball cup is the limiting factor. It can be cut/ground out to about 2.25" which is what I'd do for more flow. Y pipe is 2.5 into single 3"
Single 3" is great for a mild L98.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
