Hooker 2055HKR vs Heedman and flowtech?
Old Aug 9, 2011 | 03:14 PM
musclecarguy91's Avatar
Car: 91 Camaro Z28
Transmission: auto
I'm looking at the Hooker 2055HKR headers on summit http://www.summitracing.com/parts/HOK-2055HKR/?rtype=10
I'm also looking at the Heedman 68470 with their Heedman 17478 Y-pipe
http://www.summitracing.com/parts/HE...RO&prefilter=1
And also the Flowtech 11102FLT with their 11102YFLT
http://www.summitracing.com/parts/BIG-11102FLT/
http://www.summitracing.com/parts/BIG-11102YFLT/
I was reading on other posts and it seems as though most people get the Hooker 2055HKR's. The price of the other 2 are much cheaper than the combo. Are the Hooker's that much better? With my budget in mind I can afford the Hookers, but I would prefer the cheaper ones for money left over for additional add ons. Any help would be great. Thanks
Old Aug 9, 2011 | 03:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Hooker 2055HKR vs Heedman and flowtech?
DO those other 2 have the AIR tubes like the 2055 hookers? Thats a price adder to have AIR tubes. Hooker makes 2460's that are nice with a larger collector I think, and cheaper but dont think they come with a ypipe. They come in a variety of coatings too. Didnt know that til just now.
The others I dont think are coated and dont have AIR so they are alot cheaper.
Try asking Jet-Hot if they have any of those headers in stock and ceramic coated with their coating. Tell them you are a thirdgen.org member and heard about them through this site. They gave 10-15% discounts last 2 sets i ordered, which were 2005 and 2008 I think Been awhile but they had that discount going.
I like coated headers, they look better, run cooler and last longer
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
3" outlet vs. 2.5".
Old Aug 9, 2011 | 04:26 PM
Car: 91 Camaro Z28
Transmission: auto
I didn't realize the other ones didn't have the AIR tubes before I asked. I'll probably go with the hookers anyway. I'm thinking about getting rid of the cat as well, would all I need is an intermediate pipe for where the cat goes? Or I can just hollow it out and not have to worry about getting more pipes.
Old Aug 9, 2011 | 07:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Single cat? I hollowed mine out. YOu can put a piece of pipe there to replace it but since catback exhausts bolt to the factory cat flange, its easier to hollow the cat and keep it there.
Since you dont want the cat there, you wont need AIR system either
Old Aug 9, 2011 | 07:51 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
If you have not decided yet look at dyne dons headers. That is the best for our cars. I had hookers and wish I went dyno don.
Old Aug 10, 2011 | 10:33 AM
Car: 91 Camaro Z28
Transmission: auto
Yes it is a single cat. In my county in my state they don't check emissions, but the stuff they check needs to be visible. So I'm assuming i would need them?
Old Aug 10, 2011 | 12:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
What county in PA?
If doing visual, yes you will need AIR and the line to the cat still needs to be there. My car is still in PA, but I get around that check with the sub 5000 mile a year clause.
If you drive less than 5000 miles a year, they waive emissions checks both visual and tail pipe sniffer.
I've been doing that the last 5 years or so. Hollow cat will pass visual. I had mine on. When I went 383 with longtubes and stealth ram, i kept it under 5000 miles and had no AIR, no smog pump, no cat and it passed fine.
Old Aug 10, 2011 | 12:37 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Hooker 2460's are kind of like the 2055s in that they use a 1 5/8" primary, however the collectors are smaller and the tubing is a heavier gauge of steel so the inner diameter is smaller.
Old Aug 10, 2011 | 12:57 PM
Car: 91 Camaro Z28
Transmission: auto
What county in PA?
Schuykill county. I'll have to call and ask the place we take it for inspections about that. I don't drive it anywhere near 5000 miles
Old Aug 15, 2011 | 12:57 AM
Kraz-z's Avatar
Car: 91 z28
Engine: 305 tpi
so i was looking into getting headers. I need smog legal headers. Every post i read says go with 2055s. my question is whats the diffrence between 1990 and a 91. 2055s specs say for 85 thur 90 305/350.
Old Aug 15, 2011 | 02:02 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The dual cats for the 91-92 Z28s complicate things. The 2055's will not work with dual cats which you may have stock. In fact I think as far as staying smog legal in cali you're kinda screwed. I dont think there's anything available for you. What I cant remember is if it's only the L98s that got dual cats in 91-92 or if all Z28's got them. But that is the problem.
Some guy was saying that cats dont have to be in the stock location, just installed close to the engine, but Im not sure I'd make the investment on 2055's and just hope for the best in that regard. It's stupid, they should just let you pass or fail based on whether teh engine runs clean ,but they force you into all kinds of BS over there to do anything to your car.
Old Aug 15, 2011 | 02:41 AM
Kraz-z's Avatar
Car: 91 z28
Engine: 305 tpi
I have a single cat on my car. Is this why they say they are only for those years? so im alright if i have single cat. I thought it would mount diffrent or somthing would be in the way
Old Aug 15, 2011 | 08:22 AM
If you have a single cat car the header will work just the same. 85-92 is the same for single cat cars. Starting in 91 all L98 cars received dual cats (N10 RPO).
You can use the 2055's and remain legal because you have a single cat.
If you had dual cats you could still make it work but you'd be sacrificing legality as I'm sure whatever pipes you had made up to connect to the cats would somehow be illegal even if they do nothing different.
Old Aug 15, 2011 | 11:01 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
What he said
Old Aug 20, 2011 | 06:54 AM
Dangerous83's Avatar
Car: 83 z28
Engine: lb9
Transmission: 700r4 b&m shift kit corvette servo
Axle/Gears: 3.73 posi
i have the flowtech headers and y pipe on my car. the headers look good but the y pipe is designed like the stock one (more like "t"than a "y" ) it seems to flow just fine but i have a leak coming from my right side header that i cant seem to get rid of. its almost like the flanges on the Y pipe are set too far apart and cause the headers to miss align. if i could go back id go with something else.
*note* i did buy the dynomax cat back and it bolted up real nice and sounds awesome! i didn't even have to remove the rear axle. it was a steal for 120 bones after the 75 dollar rebate
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Night rider327
Sep 16, 2015 02:20 AM
