time to order all exhaust parts
Old Feb 19, 2012 | 09:45 AM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
ok i finally laid out how i was going to do it after being informed that a single pipe would be plenty. i have hedman ball socket long tube headers. i had a shop bend what would basically be xtensions. i will be welding it all myself and have it thought out pretty well(i think). ill try to explain it
i will be doing 2.5 into a 3 inch y pipe, then a reducer to go from 3 to 3.5 all the way back to the original muffler mount. which will be this muffler and these tailpipes.
http://www.summitracing.com/parts/MPE-12587/
http://www.summitracing.com/parts/WLK-43243/
http://www.summitracing.com/parts/WLK-43244/
for the driver side header i will do 2- 45's to get me to the y pipe and just leave the passenger side to basically go straight into the y pipe.
will 2- 3.5-45's get me over the axle? and is it ok to do a 90 bend into the muffler?
i measured yesterday and the exhaust pipe is 3.5 inches from the bottom of the floorboards, so as you can imagine, horrible ground clearance.
am i going about this right? is it laid out perfect?
thanks for the input and reading my novel
Old Feb 21, 2012 | 10:21 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
Re: time to order all exhaust parts
anybody?
Old Feb 22, 2012 | 12:43 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
finally ordered the whole exhaust along with a bunch of other stuff needed to finish up the build. hope it turns out well. ill take pics of the whole build.
Old Feb 24, 2012 | 09:51 AM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
Sorry to point this out a little late, but your muffler choice is not a Camaro configuration with the inlet & 1 outlet on the pass side and 1 outlet on the drivers side so for sure the stock pass side tailpipe won't work as designed.
You will need to find a Camaro muffler with the inlet & outlet sizes you want or you could have a muffler shop fab up dual driver side tailpipes (if there is enough space for 2).
Old Feb 24, 2012 | 11:10 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
not too sure what you were getting at but they came inlet/outlet on one side and one outlet on driver side
it is all going to be 100% made. i am going to start at the back and get the muffler/ tailpipes on first. then make the y pipe and then join them together. i understand it was a universal muffler but worst case scenario i have to get tailpipes bent. i get it all figured out though. i got it all last night. i will put it on the lift and see how well it fits.
Old Feb 24, 2012 | 03:42 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
OK, I thought you were looking for a standard Camaro set-up using a standard flow configuration for the muffler and tailpipes. The Summit description of the muffler indicates:
Inlet Diameter (in)3.500 in.
Inlet Quantity One
Inlet Location Center
Outlet Diameter (in)2.500 in.
Outlet Quantity Two
Outlet Location Offset
By the Summit photo, the centered inlet looks like it is the one that is on the single side, leaving the 2 offset outlets on the opposite side. I was confused as this is not the standard Camaro muffler configuration, so both outlets will be facing the drivers side of the car if you locate the muffler in the normal spot behind and parallel to the rear-end.
Sounds like you got it all worked out, so good luck!
Old Feb 24, 2012 | 04:06 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
OK, I guess the Summit description of the muffler is not quite right:
Inlet Quantity One
Outlet Quantity Two
By the photo, the centered inlet looks like it is the one that is on the single side, leaving the 2 offset outlets on the opposite side. I was confused as that is not the standard Camaro configuration.
Good Luck!
i see what your saying now, it is wrong, the inlet should be on the same side as an outlet... damn it, thanks for catching it. on summits website they only listed one other for a 3.5 inlet... this just sucks.
i might leave it and let people think its a v6 with a single exit if i merge them together at the end... spose its all in the name, SLEEPER
Old Feb 24, 2012 | 08:24 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Well, I would consider two tailpipes all the way out on the drivers side. Left/right symetry can be over-rated when it comes to styling . . . Tastefully unique styling will set you apart from the rest of the pack! Take a look at the Firebird wing on my Camaro. I like that I am different from the rest.
Old Feb 24, 2012 | 10:55 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
i test fit the two tailpipes on just the muffler, they fit perfect and lay side by side against each other, the only thing i will need to do is cut the turndown off and turn it 180 and extend the pipe so they are equal length. should look pretty good. just have to put the motor back in the car to support the trans so i can put it on the lift and get it all welded up
Old Feb 25, 2012 | 09:06 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Nice! When you get this done can you post a picture so I can see what it looks like? I may want to do something similar in the future . . .
Old Feb 25, 2012 | 09:14 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
well since i dont have the motor in i could only do the back section, but here it is, let me know what you think..
Attached Thumbnails time to order all exhaust parts-2012-02-25_21-54   time to order all exhaust parts-2012-02-25_21-58   time to order all exhaust parts-2012-02-25_21-55
Old Feb 25, 2012 | 09:18 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
more
Attached Thumbnails time to order all exhaust parts-2012-02-25_21-55   time to order all exhaust parts-2012-02-25_21-55   time to order all exhaust parts-2012-02-25_21-54
Old Feb 25, 2012 | 09:31 PM
rockstarr4's Avatar
Transmission: WC T5
Axle/Gears: 3.08
Nice job, that looks awesome. I love it when a problem turns into an opportunity!
Hey since you are obviously a good fabricator, you might be interested in another current post I have: https://www.thirdgen.org/forums/susp...ml#post5192929
Old Mar 16, 2012 | 01:49 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
well the machine shop has had my block for about a month now, so i will be putting in the engine i pulled out of it to lay finish the rest of the exhaust, i will be sure to take pics and post them of the final layout
Old Mar 16, 2012 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You could do a 2.5" into 3.5" merge for your ypipe. Buy a flowmaster merge pipe. Then you will have no restriction when both pipes merge to 3" on your current set of plans. This Y pipe will have a good transition from 2.5" to 3.5" single.
http://www.jegs.com/i/Flowmaster/389/Y250350/10002/-1
Old Mar 16, 2012 | 06:35 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
after i started dropping the motor in i realized the machine shop has my headers too. so it was a no go. i did get a bunch of other little stuff done. i have an extra set of headers from when i sold my 80, and was contemplating cutting them up to piece together the manifolds and crossover pipe...
i do have a y pipe, all i could find when i was at summit was their crappy cherry bomb one though, it was 2.5s into a 3, so i welded a 3 to 3.5 reducer onto it to make it a 3.5. and then i put the wideband bung on the single so i would have the a/f ratio from both sides and not just one
Old Apr 17, 2012 | 03:22 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
for those of you that actually wanted to see how it turned out, pics can be found in my build thread
https://www.thirdgen.org/forums/engi...d-install.html
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
