Edelbrock Headder Question
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Hey Everyone, a few years back I installed edelbrock ceramic headders with the AIR system on my 84 Z28 305 H.O. Since then the Y pipe has completely rotted out just before the CAT. I searched a bit on Edelbrocks website and I cant find any evidence that they even make headders anymore. Does anyone know where I can find a bolt on replacement Y pipe for this application?
Car: 83 Z28, 84 Z28
Re: Edelbrock Headder Question
I was able to locate a replacement Y pipe. The old Y-pipe is swiss cheese now, it rotted at a much faster rate than the rest of the exhaust, which is still in decent shape. I can literally peal it apart like an orange. My new question: Is there anything that I can treat the replacement Y-Pipe with to make it last longer in the long run, because my guess is that I am not going to find another Y-Pipe 5 years from now, so I need to make this one last as long as I can.
What product would it be, and what is the process if any?
http://www.youtube.com/watch?v=C8WRU...e_gdata_player
Eastwood Hi-Temp Internal Exhaust Coating and their DIY Ceramic Coating for headers. Just make sure you don't paint the catalytic converter from the inside or it will not work anymore. Where did you find the replacement y?
Engine: 4++,350 & 305 CIs
We called Edlebrock last year(?) and ordered a replacement Ypipe 4 a customers car. Not everything is listed on the web. I bet they could build a Ypipe anytime since its all programed in the exhaust bender.
Sometimes a phone call is needed when you cant find a part..
Car: 83 Z28, 84 Z28
A phone call to Edelbrock was my first step. Its how I found out that their exhaust lineup was discontinued. I asked the phone representative if there was any way I could get the replacement pipe through them and he said no. I even emailed them with further information and a second request and that has gone unanswered.
Car: 83 Z28, 84 Z28
Do you remember what phone number you used to call Edelbrock because I would still rather get a new pipe from them, the one I found is used. I called their 1800 number.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Car: 83 Z28, 84 Z28
Im not sure that would work on my 84... it says 86 to 90, not that I am sure what the difference is. This is a picture of that product and a picture of the Y pipe that I recieved slightly used for my application, followed by the current Y pipe installed on my car now.
Car: 83Z28 HO
Transmission: G Force 5 speed
I'm actually upgrading my exhaust and putting my nickel plated Edelbrock headers and slightly modified 4 bolt y-pipe up for sale. They are an HO set. I even have a pretty new CAT with the flanges that's only a few years old.
You really need to find a 83-84 HO version....or...You could do what Nelz says, and have a new Y-pipe made....but that'll be pretty costly and would be an upgrade if you had it made in SS as far as "longer lasting" goes....but it won't "breathe" any better.
You're kinda stuck either finding a 4 bolt Y-pipe, or converting to a newer non flange type. Unless you have some welding skills - then the sky's the limit...
If you search around, I would say that maybe instead of trying to save your headers, flow wise you should switch them out for Hooker Long Tubes or Dyno Don's. The TES headers have their primaries are mashed together.
Car: 83Z28 HO
But - since I switched to a 400 AND put a small blower on it, I needed more breathing room which is the only reason I personally opted for a set of Dyno Don's headers - and they're not cheap by any means...although they are great quality. Long tubes are a good solution, but on these Thirdgens, ground clearance becomes an issue with LT's.
Car: 83 Z28, 84 Z28
I dont know what part numbers will work, it seems like you have to get lucky on ebay like I did or find someone in a forum like this... other wise it seems like fabrication is the only other way to go. The pipes that subroc posted appear that they would work but they may still have to be slightly modified by the installer depending on the year / application.
Car: 83 Z28, 84 Z28
If you have edelbrock headers that you havent installed yet, I wouldn't recommend installing them for the reason that they are discontinued and it is so hard to find replacement parts for them, it will only lead to expense later.
86IROC112
Aug 17, 2015 02:00 PM
