Why is my exhaust so low? pics included
Car: 92 Formula
Engine: LB9
Transmission: M5
Pardon my newbish but im new to the platform. The previous owner (i think) lowered it and threw on some long tube headers. My questions: is there a mid pipe that goes with the headers that give them more clearance? Also, what spring setup should i use to raise my car a little?
Don't get me wrong i like low cars just as much as the next guy but when most of the undercarriage and misc. engine parts are scraped up, methinks its a bit too low... Thanks in advance!
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Why is my exhaust so low? pics included
That piping is only slightly lower than mine, your car is just low.
crappy design, I run dual 2.75" pipes and have them tucked up a lot higher than that. The only way to get it perfect is by either building from scratch or modify what you have
Car: 92 Formula
Engine: LB9
Transmission: M5
Thanks for the speedy response. What springs do you guys recommend for my 92? Should i relocate this to the suspension forum?
I would leave the susp. as is and modify the exhaust
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I say leave it low-looks good. Yeah the pipe is low, but I have had lower on my Stangs. You just have to remember how low it is and drive accordingly.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Install new motor mounts or Poly motor mounts. It will raise the engine up about 1/4-1/2in.
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
F-body is already low stock, lowering it 2" is too much for me that's like having a ferrari, can't go thru driveways or bumps without scraping **** Everytime, I'd just install a new set of original stock springs from Classic Industries and forget about it.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
kah992
Aug 19, 2015 02:55 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
