New Cat or Flowmaster...Help me DECIDE!!
Old May 18, 2012 | 09:42 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 1984 z28 carbed, and I was wondering on what I should do, replace my cat which I believe is stock but good? Or trow in a flowmaster 10 series muffler?? I am looking for some performance and sound, thanks!
I will end up doing both either way regardless but I was wondering what I really should do 1st...thanks!
Old May 20, 2012 | 01:20 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: New Cat or Flowmaster...Help me DECIDE!!
Well the sound comes froms the muffler so why would you put a aftermarket cat on with a stock muffler if your looking for sound.
Old May 20, 2012 | 02:08 PM
calgutie's Avatar
Car: 1984 Z28
thats the thing i have a flowmaster 80 series and its very quiet, so im thinking that its my cat thats bad...any other suggestions??
Old May 21, 2012 | 11:11 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
well the Flowmater 80 is not a loud muffler and put a cat infront of it and you will not have the sound you want. You could always drop the front of the mid pipe and look to see it the cat is broken or what not. My cat was all broken up inside and i had no idea till I took the mid pipe off. A high flow cat is not going to give you much more sound at all if any. The issue is the muffler.
Old May 21, 2012 | 01:50 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
. If your running the stock cat with the stock small piping that is not mandrel bent and 2.5/small exit pipes on the muffler that combo can have a effect on volume/sound.Mine has the Flowmaster 80 series American Thunder cat back with 3in. piping and 3in.exit pipes,and a high flow Magnaflow cat. and it is loud.
Old May 25, 2012 | 12:59 PM
A&TZ28's Avatar
Car: 1987 IROC Z28
Engine: LB9
Axle/Gears: 9 Bolt w/3.27's
i would probably go with a new highflow cat regardless especially if ur current one is stock. they dont flow all that well and can be a restriction even if it is fine compared to the newer flow high style cats. From there i would then chose a muffler depending on preference. magnaflow= nice quiet rumble at idle sounds great at WOT and is stainless. Everyone and there mom has a flowmasters. they sound good as well but dont flow as well as magnaflow. were u looking for an entire catback system or just mufflers?
Old Feb 14, 2026 | 03:03 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Unintentional post bump. Wish this site would do away with the feature that shows older post at the end of the newer post you are looking at.......
Old Mar 26, 2026 | 01:41 AM
Eightyninef's Avatar
If you call the big aftermarket CAT company. They will tell you straight out, it's not a high flow CAT, no matter what anything thinks.
Old Mar 26, 2026 | 01:54 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
They aren't allowed to by LAW.
Old Mar 26, 2026 | 08:38 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
I do not know if U.S. federal law does not allow the cat to be permanently from a vehicle, but in Canada if your vehicle came from the factory
with a cat, it has to be on the vehicle at all time. U can replace the cat if it fails, with an aftermarket one.
I know a local fellow, who removed the cat from is 1980's Vette and got caught by the ministry. He paid a hefty fine & had to reinstall the cat.
Old Mar 26, 2026 | 09:28 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
This is an OLD thread...
Old Mar 26, 2026 | 10:53 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Federal law doesn't allow the removal of a cat in the US either....but some states don't care so in those areas the fed gov would never know.
Old Mar 26, 2026 | 02:52 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
since your commenting on a 14 year old thread, please tell us more of what a high flow cat is or isnt?
Buggy Disaster
Oct 21, 2012 01:17 PM
Pontiackid
Apr 27, 2007 05:41 AM
luvmy64
Mar 28, 2005 11:16 PM
305RSlc
Sep 11, 2003 07:19 AM
TorchRay
Oct 20, 2002 01:31 PM
