Egr coming out of the cat.
Old Sep 9, 2012 | 07:04 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I picked up an exhaust system from an 89 iroc 5.7 yesterday and it has an egr pipe running to the catylitic converter and I want to remove it as I'm going to a carbed motor and don't want the egr showing. How can I remove this? Can I just cut the line off near the converter body?
Old Sep 9, 2012 | 07:07 PM
Twin_Turbo's Avatar
Re: Egr coming out of the cat.
it's an air pipe, not egr
Old Sep 9, 2012 | 09:35 PM
Engine: L31 350
Well what can I do to remove it? Can I just cut it off near the body?
Old Sep 9, 2012 | 09:44 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
cut it of and plug it somehow. if you don't plug it, you will have a really annoying exhaust leak. i've seen people just crimp the pipe shut and roll it back on itself to seal it, but i always just throw the cat converter in the dumpster where it belongs and run exhaust without it. i live in MN where emissions testing is something that doesn't happen, so i can get away with it...
Old Sep 9, 2012 | 10:11 PM
Engine: L31 350
we dont have emissions here either but im doing it for the ease of installing it, im going to just gut the cat by ramming a pole or something down the middle of the cat to knock all the internals apart, crimp off the air tube, and bolt it in, eventually i want to go to headers so ill do away with it then but for now i just want the ease.
Old Sep 10, 2012 | 04:17 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Ramming a pipe through it would be a bit easier with a cat with only 2 walls instead of the 4 walled cat you have. If you're not going to use the cat at all, why have one?
Old Sep 10, 2012 | 05:42 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
326 IAC 13-1.1-1 of Indiana state law defines that you must have a cat on your car.. For further questions about your state law, I have attached the link. And your 89 doesn't qualify for Antique vehicle.
http://www.in.gov/legislative/iac/T03260/A00130.PDF?
Old Sep 10, 2012 | 06:17 AM
Engine: L31 350
It's not going into an 89. It's going into my 86 and every state says you must have them but I don't have testing here so I can't get into trouble, also I'm installing the cat for now so when I get my motor in I don't have to worry about running to the exhaust shop right after, I can just bolt my intermediate pipe to the cat, and then bolt my y pipe to my manifolds. Then be able to drive it.
Old Sep 11, 2012 | 07:53 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I think it is funny how few people actually know the worth of a converter and the laws.
Just because they dont test for the emissions, dont mean that it is legal. They are required by federal law. A lot of states dont test emissions but they are still required to pass a visual inspection. In other words if it aint there, you fail.
Also, scrap price for a good converter will really surprise you. If you find a place that will grade them, you will get more. I have made as much as $80 and as low as $20 from cats Ive cut off camaros I have parted out. Had a 89 blazer converter bring $120. Imports can be worth much more. Just depends on the amount of material left inside them.
If anyone just wants the converter gone, then replace it with a short piece of pipe. Welded in preferably. Then take an old converter heat shield and weld it on around it. Looks just like a converter from the outside, flows like a straight piece of pipe, and you get the scrap value from the converter. The air tube can just be cut off a crimped over to prevent leaks.
Old Sep 11, 2012 | 04:35 PM
Engine: L31 350
and I think it's funny how you honestly don't know the laws or read what I posted above, Indiana has NO testing or inspections, I get all my tags in the mail and never have to go see anyone for my car to be legal. But I did say in the above post that every state had laws on the emissions, as it's federal. But without my state testing or inspection I am free or safer to remove them or gut the factory emissions. I want to keep my cat for now for the easy of installation when I put my new motor in. I'm going from a v6 to a v8, I want the swap to go as easy as possible. I do however plan on going with headers in the near future and will rid of the cat soon.
Old Sep 12, 2012 | 07:49 AM
3rdgenmaro's Avatar
Car: 88 IROC
Double post. oops
Old Sep 12, 2012 | 07:58 AM
3rdgenmaro's Avatar
Car: 88 IROC
Indiana has NO testing or inspections, ................But I did say in the above post that every state had laws on the emissions, as it's federal. But without my state testing or inspection I am free or safer to remove them or gut the factory emissions.
Free to remove them? No. Safer, yes. So what I said was right. Thanks for backing that up.
I never told you not to do it. In fact I told you a way to do it so that it would pass a visual. I just made anyone that reads this know that it is in fact illegal federally to do so. That doesnt mean that I agree or follow those laws, but I will state them.
"Under federal law, catalytic converters may not be removed and replaced with "converter replacement pipes" by any person. The 1990 Clean Air Act Amendments even prohibit private individuals from installing "converter replacement pipes" on their own vehicles. Anyone who installs such pipes would violate section 203(a)(3)(A) and (B) of the Clean Air Act (Act)."
Would you ever get caught? Probably not. Do I follow it? Maybe..... But once again, I feel obligated to post.
Old Sep 12, 2012 | 09:09 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Cut the pipe off and weld the opening on the converter shut...
injdinjn
Aug 28, 2015 12:51 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
