305 tbi headers?
Old Oct 22, 2012 | 04:35 PM
onebadredz28's Avatar
Car: 91 firebird vert
Engine: 305 tbi
305 tbi headers?
Hey looking into some shorties with Y pipe for my 91 firebird. Its got the 305 TBI. Just wondering what are some good ones i should look into. Not to familiar with 3rd gens. I would like to get rid of all emission etc but dont want the car to run bad because of taking it all off. Found some nice ceramic coated edelbrocks. Any help would be great! Thanks! forgot to mention it has a new 3" flowmaster cat back.
Old Oct 22, 2012 | 05:24 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: 305 tbi headers?
Check out these:
https://www.thirdgen.org/forums/exha...n-headers.html
Old Oct 22, 2012 | 05:36 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
Car want run bad by taking off the smog pump and the air tubes that clutter up the engine bay. Worst that'll happen is if you have emissions testing or the cops are ones to look under the hood and ticket you for modifying the emissions system you'd probably want to look for something that keeps the air tubes. Can't speak for a specific brand as I still have iron manifolds but look for thick flanges/tubing and make sure it has a bung for the o2 sensor. Also if you can afford it go for the ceramic coating, painted headers will rust in a week or so.
Old Oct 22, 2012 | 06:10 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
The headers in the link are the only shorty headers with 1 3/4" primaries. You can get with or without the air tubes. They are now being made from aluminum steel and are ceramic coated and can be ordered with a custom Y-pipe.
Old Oct 24, 2012 | 12:43 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
i got the hooker shorty headers from jegs, i forgot the number but they're the ones with out the air tube connections. I love my hooker headers but i would go with the ceramic coated, i got the high temp paint but the paint they use is cheap and is gone after a month. I'm gonna repaint them with some good high temp paint
Old Oct 24, 2012 | 12:48 AM
bigreed91's Avatar
Car: 1990 camaro rs
here's what they look like installed and you can see how it looks without the air piping
Old Nov 7, 2012 | 07:01 PM
Engine: 305 tbi
Also with a tbi can i delete the o2's or do they need to stay? thanks also theres a metal tube right before the cat. I think its part of pollution system. anyway its in bad shape. Can that be thrown away also with getting headers?. Btw its a 91 firebird.
Old Nov 7, 2012 | 09:04 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you will need the O2 , and may need to install a bung for it . not a big deal , i installed mine on the Y pipe . just about 3" below the lt. side connection . good luck .
Old Nov 13, 2012 | 09:22 PM
Engine: 305 tbi
thanks for the reply's! Well im either going with coated hooker 2460's and y pipe or dyno don's shortys with y pipe. want the one thats going to install the easiest and last! only thing with hooker im on edge about is the y pipe. heard thats hit or miss
Old Nov 13, 2012 | 09:38 PM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Yep its part of the smog pump. If you have to keep the converter to pass emissions just cut it off close to the converter then pinch the converter end flat and seal it up with some welding. If you don't have to keep the converter just get rid of it, when they get old they'll clog up plus the exhaust sounds better without it.
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
92purpz28
Aug 11, 2015 02:30 PM
