Stock Muffler Questions
Old Dec 24, 2012 | 12:22 AM
zbowles's Avatar
Car: '84 Monte Carlo SS, '84 Z/28
Engine: GMPP 350, stock 305
Transmission: TH350, 700r4
Axle/Gears: 3.42 open, 3.23 posi
Welp, my dad has owned his '84 Z/28 with the LG4 since about '87. The muffler's guts have rotted out but the case is solid. I wanna know, does anyone make a reproduction muffler that's the same as stock or should I weld new baffles in the old case? In that case, where could one find drawings or pictures of the stock guts?
Is there any difference in mufflers on Z/28s over the years or will they be the same? Because, if anyone wants to get rid of a set of stock the same mufflers that are good or are sacrificial, let me know.
Thanks.
Old Dec 24, 2012 | 06:41 AM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
Re: Stock Muffler Questions
I think the Dynomax is the closest looking to original. The tailpipes are very close, but not exact. I had one on my last car, LG4 with factory manifolds and cat. I did not think it was very loud. The tailpipes tuck up under the bumper nicely.
Old Dec 24, 2012 | 08:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. Some early models (IIRC, 82-85 LG4/LU5) did have an exhaust with two mufflers and a tip per muffler. Crawl under and take a peek.
JamesC
Old Dec 24, 2012 | 08:25 AM
zbowles's Avatar
The reason we want to keep factory mufflers on the car is originality. The car's exhaust hasn't ever been changed, everything is numbers matching, etc. If anything is broken, 99% of the time it is replaced by a GM part. We like modified cars and realize our isnt worth much but its just like a rolling time machine which others can be measured.
JamesC
Yeah, the car has two mufflers and didnt come from the factory with cats. Its an '84 Z/28 with the LG4 and 700r4. This is going to make it a pain to find mufflers, isnt it. :/
Old Dec 24, 2012 | 08:33 AM
JamesC's Avatar
Should have a single cat. I haven't seen OE-type replacement mufflers for those years.
JamesC
Old Dec 24, 2012 | 08:53 AM
zbowles's Avatar
JamesC
Ill check again. I just remembered going to a junkyard once that'll probably have em. Thanks for jogging my memory! Ill check with them.
Old Dec 24, 2012 | 10:20 AM
Oh, I totally understand, but I think you are fighting a losing battle. There are others over on the history section who have made old exhaust systems look brand new.
Old Dec 24, 2012 | 02:17 PM
Here is the post from the history section, about a stock muffler restoration. Chazman did a fantastic got this old stock muffler looking almost new. I know that the muffler is different than yours, but a great example of what can be done with old parts that some think are worthless.
pics start at post 140:
https://www.thirdgen.org/forums/hist...ow-iroc-3.html
Unfortunately, my stock exhaust rotted away from the inside out. Patch a piece here, cover a hole there, but eventually the thing literally fell off the car.
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
