dual exhaust problems
Old Mar 29, 2013 | 11:29 AM
jay86TAsmith's Avatar
Car: 1986 Pontiac trans am
Engine: L69 305 H.O.
Transmission: Norg werner T5
i call for a price check on a true 3" dual from headers back and they said that it cant be done but they can have the duals run to the back axle and it has to go into 1 to go over it. but they said they can true dual that will come out infront of the back tires has anyone tried this? i want a nice gurnt to it not to sound like a weedeater like a honda and its going to be on a 305 H.O. trans am and i need some advice
Old Mar 29, 2013 | 02:15 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: dual exhaust problems
There Is Just No Room To Run True Duals On A 3rd Gen.
Old Mar 30, 2013 | 09:36 AM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
It can be done but you will have to find a different upper Panhard bar
Honestly for a 305 you do not need 3 inches. 2.5 Will be more than enough.
Also with 2.5 you do not have to do anything different and THEY WILL go over the rear axel on the passanger side.
Proof
Old Mar 30, 2013 | 11:13 AM
83 Crossfire TA's Avatar
Right. Those are clearly 2.5"... 3" is really pretty tight as a single. Dual 3" could probably be made to work by someone really good but if i owned a shop I'd stay away because of the hassle and time involved unless I knew that the customer was willing to pay way too much (to cover the time fussing with it) for something that would likely never fit quite right. A lowered pan hard brace or dumps before the axle would help enormously
Old Mar 30, 2013 | 08:01 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
many have.
im in the middle of it know its just incredibly hard. i have it mocked up now with flexible pipe, there is room to go over each side of the axle like a traditional dual pipe setup. mine will have the mufflers where the stock tailpipes were and i will be able to get the tank down without messing with exhaust
Old Mar 30, 2013 | 10:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, your exhaust guy is correct, you can't do dual 3" exhaust over the axle, thru 2 mufflers and have 2 tail pipes at all.https://www.thirdgen.org/forums/post...3-post428.html
Buuut to do it properly you'll have atleast, atleast, $1,000 - $2,000 to have it done correctly.
Most will not take the time to do it right.
Old Apr 1, 2013 | 04:10 PM
ok well i wanted 3" because i ordered a 350 engine for it but he said something about running them out the side in front of the back tires have anyone of you done that before or would know how it would sound
Old Apr 1, 2013 | 04:15 PM
TTOP350's Avatar
A good quality single 3" catback with dual/single tail pipes will be just fine for your needs.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
