cheap exhaust question
Old Apr 10, 2013 | 06:10 PM
rwriley563's Avatar
Car: 89 rs
Engine: 305 tbi
Transmission: autotradgic
Are there or does anyone know of a stock sbc manifold that flows better and is a direct bolt in? Would like to get a little more hp outta my 305 tbi as cheaply as possible as it is a continuing process fixing al of the other minor problems with it first before I do a 350 swap. So most of my funds are going to that as it is a daily seasonal driver. Thanks in advance
Old Apr 10, 2013 | 09:50 PM
82tarecaro's Avatar
Re: cheap exhaust question
L98 or L69 exhaust manifolds and Y pipe would be the only other manifold/ Y pipe that would fit besides stepping up to a set of headers.
Old Apr 11, 2013 | 10:31 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
the 350 and 305 headers are the same, you could get them anytime and run them on either.
Old Apr 11, 2013 | 12:59 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
You're wasting your time and cash swapping to different manifolds.
The time and effort will not be rewarded with even a noticable gain in performance.
But some shorty hedmans and y pipe, or jegs brand.
Old Apr 14, 2013 | 07:17 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
or search for a used set of hookers or SLP headers. deals can be found
Old Apr 14, 2013 | 09:34 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Well, you may get a bigger bang for your buck by going to headers, but I did get a noticeable improvement on my CFI by going to L69 exhaust manifolds.
Old Apr 14, 2013 | 11:33 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The gains from swapping to L69 or TPI manifolds is not all in the increased diameter of the cast iron manifolds but in the ability to connect the much larger y pipe that is specific to them. JamesC has several threads related to this, including this one:
https://www.thirdgen.org/forums/exha...aust-pics.html
Old Apr 23, 2013 | 11:35 PM
83 Crossfire TA's Avatar
I would actually be surprised if LT1 manifolds didn't fit, and they're a significantly better design... Would they make more power? Donno...
Vintageracer
Jan 10, 2020 05:33 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
