Changing Plugs W/ Hooker 2055's
Old Jun 2, 2013 | 10:11 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Iv read all the theories but was wondering if anyone has actually done this with out using a shorty plug or is it impossible?
Old Jun 2, 2013 | 03:17 PM
Guest
Guest
Posts: n/a
Re: Changing Plugs W/ Hooker 2055's
Just get the shorties and be done with it..........you have been warned.
Old Jun 2, 2013 | 03:31 PM
insomniac's Avatar
Engine: 5.7 L98
lot of people on here say they suck. but even if I swap to them I have to get the ones that are in it out...
Old Jun 2, 2013 | 04:42 PM
Guest
Guest
Posts: n/a
Iv never heard any one say that shoties suck.
Old Jun 3, 2013 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/afte...w-headers.html
JamesC
Old Jun 3, 2013 | 08:59 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
I have 2055 headers with angle plug heads. I run standard length plugs and can get them all out with a standard spark plug socket, but its kind of a pita. I think I will probably get the go-thru socket set from Harbor Freight that JamesC linked to. That looks like it will make it a lot easier.
Old Jun 3, 2013 | 11:58 AM
Guest
Guest
Posts: n/a
I have that go-threw socket set...you still need room to get it on and off the plugs...
-get the shorties
Old Jun 5, 2013 | 10:13 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
There was an article in Hot Rod years ago (Feb 2000), and the guy was talking about changing the plugs with headers on a Firebird. He took a spark plug socket that had a hex head on the end, and cut it off so the inner hex bottomed out on the plug and the plug sticks through where you would normally insert the ratchet, then uses a wrench on the outer hex. I tried it, works great.
Old Jun 5, 2013 | 10:50 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I have hooker 2055s and changing plugs is a no brainer once you've done it a couple times. I can get all 8 in/out from up top (Keep in mind I have done everything I can to clean up the engine bay and my car has no emissions equipment so I hacksawed the air tubes off the headers and had the holes welded).
Shorties are a MUST. I run NGK shorties and have never had a problem with them. Never misfire. Some of the plugs you can get with a regular socket. Other ones I use a shorty socket. There was a guy on ebay who was selling them however you can make your own. This is done by cutting a regular 5/8 spark plug socket in half then drill out where a ratchet would normally attach. This allows the socket to slide over the spark plug socket and you then use a 3/4 wrench to turn it. I believe maybe 1 or 2 of the plugs I use no socket and just slip the box end of a wrench over the plug nut.
A few of the plugs I have to snake my arm throughout the headers to get to, namely the #6 and #8 plugs but I'm used to it now. Changing plugs is no sweat for me with 2055s.
deracer
Apr 11, 2016 12:04 AM
tricky1
Aug 23, 2015 01:17 PM
TRAXION
Nov 11, 2002 03:31 AM
five7kid
Carburetors
Oct 5, 2001 12:36 PM
