Hooker Super Comp Headers
Old Sep 22, 2013 | 09:30 PM
SeanCole822's Avatar
Car: Pontiac firebird
Engine: 350 V8
Transmission: Automatic
I have hooker super competition headers on my 89 trans am with a 350 engine and they are the worst! They are in the way of the boots on the spark plugs and the only way to get to the spark plugs is to get a 30$ socket or take the headers loose! They eat up wires like crazy. So if anyone is thinkin about gettin these dont!
Old Sep 22, 2013 | 10:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Hooker Super Comp Headers
Sweet, I've had the 1 3/4 H-SC-LTs on my car for almost 20 years, no issues.
Old Sep 23, 2013 | 12:45 AM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
running straight plug heads? not angle plug? that is the only thing I can think of that would cause interference between the spark plugs and the headers. I have been running Hooker LT's on my car with no spark plug clearance issues. I am using autolite or ngk plugs with 90* boots of the plug side of the wires.
Old Sep 23, 2013 | 06:30 AM
Engine: 350 V8
Im running 90* boots, the plugs are behind or really close to each header tube, idk maybe i just got bad luck with these headers! But yeah im usin autolight and using heat gaurd sleeves on the boots that are touching the header
Old Sep 23, 2013 | 08:35 AM
TTOP350's Avatar
On a mostly stock car, you really won't have any power increase over a nice set of Dyno Dons shorty headers and Y pipe, which fit much better.
Long tubes aren't really worth it until you get past 500 or so RWHP.
Its also a good idea to spring for jet-hot coating.
Old Sep 23, 2013 | 08:57 AM
Guest
Guest
Posts: n/a
Same hear.
YOU NEED THE SHORTIE SPARK PLUGS!
-go to the parts store, their accel's and they should be next to the MSD stuff behind the counter-
Old Sep 23, 2013 | 10:12 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Weird I dont have any of those issues.
I use one of these, works great
http://www.harborfreight.com/21-piec...set-67974.html
Old Sep 23, 2013 | 08:15 PM
Guest
Guest
Posts: n/a
I have that socket set up, works great. A def. good buy.
Old Sep 24, 2013 | 07:57 AM
midias's Avatar
Originally Posted by evgax58
Same hear.
http://www.jegs.com/i/NGK-Spark-Plug...673-7/10002/-1
I use these no problem.
Old Sep 25, 2013 | 08:41 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
welcome to the wonderful world of headers!! personally, I have never met a set that didn't give some problem some where. they are a good way of making more power. but IMHO they just aren't worth the head aches that they cause
Old Sep 29, 2013 | 05:58 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Doug's long tubes here no fitment issues plenty of ground cleareance
Old Sep 29, 2013 | 09:49 PM
Guest
Guest
Posts: n/a
My Doug LTs realy only scrape the ground on the pass side header.
The bottom of 2 primaries just before the collector...
Old Sep 30, 2013 | 08:51 AM
Ingram78's Avatar
Car: 1985 firebird
Lowered?^^^
Old Sep 30, 2013 | 09:07 AM
Guest
Guest
Posts: n/a
Originally Posted by Ingram78
Lowered?^^^
Hotchkiss 1" drop springs
Lake wood 70/30 struts
Rear
Mooge springs
Lake wood 50/50 shocks
All Founders rear bars, ect.
I think its the front going up and down due to the "drag" struts", if I time tapping the brakes just before huge dips and such, it won't scrape or scrape as hard. I don't even think my Mufflex Y even scrapes...
Also you'd think that the drivers side with the drivers weight, that the DRV side would scrape. But their are only a few scratches, the pass side is ovaled...
Old Sep 30, 2013 | 04:01 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
My hookers fit fine, Accel shortie plugs and I have half an inch or more room in some places.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
