exhaust
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
exhaust
So my exhaust the pipes come right under my door and are basically hidden I've never seen this exhaust on body I mean I'm sure there out there it's just custom anyways I'd like to have email come out with chrome tips or maybe have chrome.e pipes under the door and take off the cover what are your thoughts anyone got pics of same exhaust???
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: exhaust
if your exhaust ends under the car its illegal since some the the exhaust will seep into the car and give you carbon monoxide poisoning.
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: exhaust
i cant understand what your saying.
"I'd like to have email come out with chrome tips" what does that mean?
"pipes under the door" sidepipes?
Car: firebird 91
Re: exhaust
Yea there's no way its illegal bro Ive seen same setup on other cars but I meant to say id lik to put chrome tips and have it come out a little more.have you ever seen the older cars the exhaust is right under the door
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: exhaust
There is a lot of work that needs to be done to have them dump out the side. If you don't go through the frame rail you lose a whole lot of ground clearance.
There is a member on here to was doing a "Boom Tube" NASCAR style side exhaust but he had to cut the frame rail to make it work. It looked sweet and was REALLY loud, but...I can't help but think he'd run into structual problems later on.
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: exhaust
i guess your state laws will dictate the legality?
i was sitting here thinking about side exit exhaust. i've had 3 vehicles over the years that i can think of with side exhaust. the only one i didnt mind was an old truck. i had the side exit on a 71 chevelle when i was a kid, (with the old cable operated cut-outs, lol). now that car sat higher than a 3rd gen, and still dragged the road once in a while. it also sounded like a truck at low RPMs.
then i had a 78 camaro with side exhaust. same thing, sounded "truckish", bottomed out now and then, and i actually ripped part of it off on a speed bump and ran it over! dont really remember getting burnt on them.
i guess what i'm getting at is, it's not a great idea. these cars are low as it is, you'll want all the ground clearance you can get. your car will be safer and sound better to run it out the back. at the least i'd run it down the center as high as possible and dump it before the rear, but it will be louder then going over the rear and out the back.
just my thoughts.
just my thoughts.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: firebird 91
Re: exhaust
Idk if I can gt ti through inspection what's that maybe you should look at what you write before you post lol noones perfect king midias
Re: exhaust
Perfect or not you are insulting the board by not even making an effort to post anything legible.
I think you would get more help if you double checked your information unless you are really curious about email coming out of chrome tips.
Car: firebird 91
Re: exhaust
Sorry if I mispelled things forgot this was a spelling bee its 2014. Now. Nd if u cnt understand my writing u must b stupid but as far as the exhaust I live in mass.anyone familar w the law my boy said if ur car is over 16 years old your car is strait neon kno???
Re: exhaust
I don't know your boy or how being 16 years old turns your car into a straight neon. Hell I did not even know there were bent neons but I am guessing they are the under 16 crowd.
The best thing you can do is what I already told you. Call the shop and ask. Also call the DMV and ask. Don't take you "boys" advice or anyone from the board. Call the local officials for your inspection and get a good answer.
Car: firebird 91
Re: exhaust
Ok in mass if ur car was 83 or older you'd be okay obv they changed ithttps://www.thirdgen.org/forums/exhaust/250465-new-massachusetts-exhaust-law.html
david068513
Sep 18, 2015 10:36 AM
