Looking for Dyno Don header install tip
Old Mar 15, 2014 | 09:25 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
I am installing Dyno Don headers on my 87 Camaro, L98 auto, 88+ serpentine accessories.
The driver's side practically fell into place... OK, I recently did the Astro steering shaft mod, so that wasn't frozen in place, and came out again easily. At that time, I already bent the brake lines out of the way, so I had lots of clearance to get the header in.
The passenger's side is much tighter. The AC housing certainly doesn't help. Manifold is out (duh!), as are the plugs, AIR diverter, and starter...
1) Install from the top or bottom?
2) Will removing the valve cover make a difference?... just that much extra clearance?
3) Do I have to eliminate the metal coolant line on the frame?
4) Pull the passenger's side motor mount bolt and lift the engine a little?
Thanks,
Joe
Old Mar 15, 2014 | 09:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Looking for Dyno Don header install tip
Old Mar 15, 2014 | 09:57 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Thanks, Don. Thanks, too, for the quick build.
1992rs/ss
Jan 31, 2025 05:10 PM
rocn7roc
Sep 21, 2021 02:16 PM
1984HO
Mar 19, 2021 11:59 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NinjaNife
Aug 23, 2015 11:49 AM
