Dynomax For The Win?
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
So within the next week, after my 19th B-day(
) I will be having a well known exhaust shop (not enough time with work and school going on) Perform a bad*** exhaust set up. Tomorrow I will post a exhaust video of before. Specs of before. 1991 stock LO3(low mileage, 133k!) Stock mani's with the cat removed, and air plugged u p. from the mani's theres 2 1/4 all the way back to the backwards muffler. Now by backwards I mean (I'll use a single inlet duel outlet flowmaster here for a example) the pipe from the engine is entering the furthest out outlet, and then the inlet is being used as and outlet as well as the other outlet being used for normal outlet... confusing right? So this causes backwards flow, and bad (kinda) performance. Also sounds, different.
New setup. Flowtech Lt's, (do not know part number, got them for cheap) I believe 1 3/4 primaries (Hope I am wording this right) with a 3 inch collector. Then a 3in all the way out with a ebay 'X' pipe, (3 inch on all sides) and Summit Dynomax Race Bullets, p# 24250. I may end up doing 2 1/5 all the way out, but as for now, this is what its gonna hopefully sound like....
https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D0z5lA6a76rY&h=8AQHmWIVa
Will 3 inch all the way through be to much for the stock(not for long) LO3? Can't wait to get it done!!
) I will be having a well known exhaust shop (not enough time with work and school going on) Perform a bad*** exhaust set up. Tomorrow I will post a exhaust video of before. Specs of before. 1991 stock LO3(low mileage, 133k!) Stock mani's with the cat removed, and air plugged u p. from the mani's theres 2 1/4 all the way back to the backwards muffler. Now by backwards I mean (I'll use a single inlet duel outlet flowmaster here for a example) the pipe from the engine is entering the furthest out outlet, and then the inlet is being used as and outlet as well as the other outlet being used for normal outlet... confusing right? So this causes backwards flow, and bad (kinda) performance. Also sounds, different. New setup. Flowtech Lt's, (do not know part number, got them for cheap) I believe 1 3/4 primaries (Hope I am wording this right) with a 3 inch collector. Then a 3in all the way out with a ebay 'X' pipe, (3 inch on all sides) and Summit Dynomax Race Bullets, p# 24250. I may end up doing 2 1/5 all the way out, but as for now, this is what its gonna hopefully sound like....
Last edited by Mr.ChevyStroker; May 8, 2014 at 11:06 PM. Reason: terrible grammar, my apologies
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Dynomax For The Win?
You may need to separate the link from the sentence below it to get it to work.
I would not even consider anything but a 3" including the outlet/tips.
Sounds overkill for a 305 tbi. I would wait till you upgrade the engine to start adding long tubes and better exhaust if you can wait.
Car: RS Camaro
Ill repost the link. I already have thr Lt's for it. I just need the gaskets and them ill be golden. Most people run 3 inch on there 305s so I was thinking why no I?
Car: 1983 Z28
Engine: 385 Fastburn
because true dual 3" pipes are serious overkill for a 305, and honestly anything that's not pushing 650 hp and up.
If you are going the true dual route, with that engine, 2" or 2.25" would perform the best.
Car: RS Camaro
dual 3 inches, thats why I was gonna run an 'X' pipe but i can be over kill i would guess.. :P
Car: RS Camaro
But i also have the intention off intake, cam and heads as well as some flat tops and such. kind of a sleeper dealio. Everyone builds a 350, or a ls1... Which isn't bad! Theres a reason why everyone does it. But its gonna be my DD, with track days here and there...
Car: RS Camaro
I was just thinking I could probably just do a single 3 in y pipe, and then after the pipe gets over the torsion bars i could put the dynomax there, but its gonna be fricking loud, SI could also do a 3 in y pipe, and just one Dynomax bullet, then just y it out the back yeah? Would that work?
Car: 1983 Z28
A 3" Y would work, I've even seen a guy on here who did a Single 4" from the Y to the muffler (I think he affectionately called it a stove pipe lol)
Car: RS Camaro
Wiuld be hard to make the single 3 into a dual 3s? I dont think it should be too hard.
Car: 1983 Z28
My engine is putting out 400+ hp at the moment and the dual 2.5" breathes very well. I just recommend 2 or 2.25 based on how my current set up is.
At the end of the day, if you want dual 3" then it's within your power to make that happen.
Engine: TBI,5.0
A 3in. collector tapering down to 2.5 did not seem right to me.
Also I believe the 3in. pipe with a 3in. exit pipe will give him a deeper tone.
I’m most defiantly not an exhaust expert but IMO believe that's about right .
Car: RS Camaro
Ill probably since i already accidently ordered the 'X' pipe, from ebay, So i still may do the duals, but 2 1/5 instead. But i could always sell the X pipe and run a fatty 3 in why and then use two 3 inch exit pipes. That should be just as good as a dual 2 1/2's right?
Car: RS Camaro
Sorry about my bad spelling and grammar... I could sell the X pipe and run A)
A nice big 3 inch 'Y' into 1 Dynomax bullet, then after the bullet have it split into a dual exit of 3 inch, should exhaust flow out of each side mostly even?
B) Or will it not matter to much? otherwise I'll run the X pipe and 2.25 or 2.5 to the x pipe and out then 3 inch after both bullets all the way out the back...
Which sounds like a better idea?
Car: !983 Z28
Engine: 355
Transmission: rebuilt 700R4
Axle/Gears: possi rear end
I am having the same problem! Right now I have the original 305, but will be rebuilding the tranny and putin a 327 in this summer. Which setup would you guys use... Magnaflow or dynomax? I think thy both sound great, just need some advice from fellow 3rd gen enthusiasts!! 3"pipes? I am gonna get the muffler and have my local shop do the rest of the work!! So I know its done right!! Thanks for the help!!
Car: RS Camaro
Normally a 3" catback set is plenty for a 3rd gen no matter what. But I wanna run different exhaust compare d to carback. They make some bad*** kits tthough! !
Car: RS Camaro
I know! I love that sound! Thats why I was like... New exhaust? I think yes!! And they make some boss cat back kits with out any modifaction hardly that sound raw Amaro83
Car: 1983 Z28
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
you are going to have a TERRIBLE time fitting a x-pipe under our cars, most everyone runs a y-pipe. those who run X-pipes custom make them. i dont think you are going to have luck with an x-pipe, let alone a universal Ebay one
Car: !983 Z28
Engine: 355
Thanks for all the help!! So which muffler should I go with for that raw sound? There are so many to choose from its crazy!! This car is my baby, so I want her to sound as good as she possibly can!! Nothhin but the best!! ha ha!!
Car: RS Camaro
Anything is good really. Just depends on what ypu prefer. Go to YouTube and just type the year and motor of your camaro and look through flowmaster magnaflow etc..
Car: !983 Z28
Engine: 355
I finally founs exactly what I'vebeen lookin for!! Gonna get a Dynomax Ultra Flo SS. I found it in a classic industries magazine!! I couldn't be happier!!! They have the one in, one out, and they even have the one in, 2 out like our cars are suppose to be!! Love this magazine!!
Car: RS Camaro
Well the x pipe came today so ill find out how it will fit soon... Hoping. Haha
Car: !983 Z28
Engine: 355
Keep us updated on how the x pipe fits! If you can, post pictures so I can see how much ground clearance youu have. I sure don't have much under minne.
Car: !983 Z28
Engine: 355
I thought I would also tell ya that my car doesn' have a cat. The guys who had her before me took it all off and just welded a pipe where it was. They were trying to get as much hp as possible. The guy said he used her for drifting. (cringe) lol
Car: RS Camaro
Sorry I havent replied these last couple days, cant decide on what exhaust i am gonna completely do just yet, but since its so late where im at right now im just gonna post a few pictures in the morning an a video of the bottom end of my car and how the exhaust is right now, depending on another friends kit for his 77 lt, i may or may not be using the x pipe. The video will show the route i will mostly likely use for true duals. But i may end up gettin a magnaflow catback, or something instead, I just cant decide. I know a 2 1/4 duals flows more than a 3 inch y pipe catback system, but will it be cheaper than true duals possibly? And I love true dual sound, but since gm gave pencils to some monkey to design the floor boards and such its a little hard without any frame mods or nothing, (give or take crossmembers and such) But you guys can help me decide tomorrow!
Car: RS Camaro
I feel dumb, but how do I attach videos and images from my saved stuff, it keep asking me to type in a url... Anyone have the answer?
Car: RS Camaro
http://20140516_1610141.gp
thats the video from the undercarriage of the car, and ill post some pics as well here in the next post..
Car: RS Camaro
Heres the exhaust pics.
The y pipe for the manifolds
Through the crazzy route
Where the cat was, and hopes X pipe will be put!
By the driveshaft and such
Another further shot of driveshaft
Over the axle
The others ones Ill post later, they are just the muffler and another cat area shot. But 2.5 is definitely manageble and 3 inch Dnomax's! Right? For some reason it wont show the pictures... I apologize for my stupidity on here again...
Over the axle
Last edited by Mr.ChevyStroker; May 25, 2014 at 02:31 AM. Reason: Yahoo probs;I dont know how to get the picture in the flipping comment! :(
Car: RS Camaro
Okay so I made the decision! I ordered Hookers 2460HKR shorties, and a single 3 inch dynomax, y pipe all the way out. It'l be a little more cost effective since I found out how much the shops were charging to do true duals on a third gen.. (racists
) So all I am waiting for is the muffler and then itl be sweet! Ill try and get a exhaust clip before hand.
) So all I am waiting for is the muffler and then itl be sweet! Ill try and get a exhaust clip before hand. Last edited by Mr.ChevyStroker; Jun 22, 2014 at 12:22 PM. Reason: Changed my mind, and had some wrong information in the text.
Hotrodboba400
Dec 10, 2019 07:07 PM
Angie Coots
Sep 23, 2015 07:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
