help air pump delete
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Hello where i live my old car 1989 trans am 5.7 dont need a cat to pass inspection and when the cat went bad i replaced it with a pipe. I dont want to remove the airpump for now and have closed the airpipe where it normal goes to the cat is that okay or ????
thanks claus
thanks claus
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: help air pump delete
I see claus and I think of the Fish from American Dad. Anyway, delete that bi...big piece of weight. I bought my delete pulley from Hawks years ago, when it was about $45. Almost double now, but here you go. Hawks Smog Delete Pulley
TPIParts has it for $84.
Axle/Gears: 10 Bolt 2.73 Open
$69.25
http://www.ebay.com/itm/131034924958...l2649#shpCntId
While some ebayers won't ship overseas, this one lists Denmark as a location they will ship to.
This one you linked to says A/C delete. I think the OP is after the air pump version. I'm assuming they are not interchangeable?
Car: 89' IROC-Z
Engine: LO3
Correct, but the part number is for the Smog Delete Pulley. Plus the picture shows the 2bolt design of the smog delete pulley as well. It's just a typo. It's why I always search Part#'s.
Car: 89 Iroc
Engine: 5.0L
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Y does everyone buy a pulley you can remove it and install a smaller belt if its serpentine. I've been running this setup for years its cheaper and lighter weight!
I'll have to check my recites I just bought on I think the replacement was a 70. Most auto parts stores will let you buy multiple and bring back what you don't need.
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
you will need a 96.8", 6 rib belt and look up the re-routing on this site.
Car: 89 Firebird
Engine: 355 TBI
I bought a 96.8 in belt just like I did on my last TPI engine and removed smog pump and the belt was too dang long for the TBI engine.. I put it back on and will probably get the smog delete pulley from Amazon or get a string around it and measure like I should have first.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
You sure you got the right belt and have it routed right? Works fine on my 91 TBI.
Car: 89 Firebird
Engine: 355 TBI
Im going to measure the belt myself it was listed 96.5 or 96.8 in if I can remember but you know things get mixed up in packaging sometimes. As far as the route yea I had a diagram and checked it over good. I was in a hurry and didn't physically measure the belt but im sure they will make good on it and trade me another if it wasn't what I ordered.
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
Serpentine setup is the same for tpi and tbi. I bought the 968k6 and used the alternate routing. Worked great.
Car: 89 Firebird
Engine: 355 TBI
I just went ahead and ordered the $48 smog delete pulley from Amazon. It does look a little cleaner with it instead of the hole it leaves when you take out the smog pump all together imo.
mcquigg
Aug 13, 2015 02:26 PM
