Header gaskets
Old May 22, 2014 | 04:40 PM
racerx520's Avatar
Header gaskets
i set up this thread a while ago :https://www.thirdgen.org/forums/exha...hell-need.html
I have D-port exhaust on my heads, round port hooker headers. they seem to be leaking on my first start up. did i use the wrong gaskets? should i have used round port gaskets instead?
Old May 23, 2014 | 10:29 AM
racerx520's Avatar
Re: Header gaskets
i called up summit today, they said to get the gasket to match the header flange and not the exhaust port on the head. i was wondering if anyone knew of SCE brand was any good? thats the only one they list in copper oval port.
Old May 24, 2014 | 02:33 PM
Marc 85Z28's Avatar
Re: Header gaskets
Don't EVER contact Summit or Jegs for tech advice!!!!
Match the gasket to the HEAD, not the header flange.
Use these: http://www.summitracing.com/parts/tfs-30490931
MLS gaskets are far superior to anything else, will never blow out, and can be reused multiple times.
Old May 24, 2014 | 06:57 PM
racerx520's Avatar
Re: Header gaskets
they did make a good point though in regards to the gasket, with the D-port, i have an opening at the bottom of the gasket with the header. if i get oval gaskets then that'll cover the whole thing
Old May 24, 2014 | 07:45 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Re: Header gaskets
I used header gaskets from autozone for the L98 aluminum corvette heads and they worked like a charm on my Dyno dons headers
Old May 24, 2014 | 08:31 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Re: Header gaskets
I run Fel-Pro 1406 on my D port heads
Old May 24, 2014 | 10:13 PM
racerx520's Avatar
Re: Header gaskets
my issue is i have D port heads, and oval port headers. i was told by lots of people here that it would work, it would appear as though i got the wrong gasket though. i'm going to try and replace it sometime next week and hopefully i'll have no more noise out of it
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
