Any body have their muffler mounted infront of the rear end?
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
-When I say in front of the rear end, I mean along the drive shaft and torque arm.
Like in front of the yoke on the rear end. (mounted under the center of the floor back their)
---post pics---
---post pics---
Car: 89 Firebird
Engine: 355 TBI
Re: Any body have their muffler mounted infront of the rear end?
Ive ran a glass pack where the cat-converter was and no muffler in the back in several of my cars before. It sounded ok.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Ran a round dynomax just before rear axle next to driveshaft pinion yoke and then went up over the axle. Clearance was ok considering 6" thick case
Car: 91 ws6
Engine: Carb'd 334 stroker
I'm running true dual stacks, no cat with one glasspak per side, exiting out the side and going up in between the door window and the hatch. Sounds kinda like a Harley, somehow.
Car: 88 IROC-Z
Edited the first post
i thought i saw a member on here once ran true dual mufflers in that area. cant remember the post it was in, or what kind of mufflers they were. i know, i'm such a great help.
Car: 1983 Z28
Engine: 385 Fastburn
Here's my set up. Longtubes, true dual 2.5" dumped just before the rear axle. Thrush welded mufflers.
Car: 88 IROC-Z
^This guy is close, im trying to run -1- muffler in the absolute center back their.
My I pipe slipped out the back of my Mufflex Y pipe for my LTs (as usual...because its not welded) so my exhaust was hanging low with a steel rod in the I pipe and Y pipe to keep the I pipe off the ground.
I was driving and I saw this huge street cover so I came to a complete stop, then inch over it and bamn. The I pipe got caught on the thing and got waded and twisted up, so I cut it off.
Since im not gonna waste money on another cat back, im just gonna put my Maxflow muffler on the back of the Mufflex Y pipe and be done with all this.
RedLeader289 - do you have any more pics of the mufflers but from the sides back their?
Car: 1983 Z28
I have about 4-5" of clearance on the lowest hanging part. BUT I'm also running 275/60/R15 tires in the back, which give me an inch more height than stock tires.
Car: 91 camaro rs
Engine: 305 tbi
Axle/Gears: 2.73 :( posi :)
Do u have any sound samples or a video of how ur exhaust setup sounds like? I have the exact same setup I'm waiting to install on my 91rs. Just waiting for payday to get my o2 sensors
Car: 1983 Z28
http://www.thrushexhaust.com/products.html
It's a pretty loud setup and allows for the engine to breathe nice and plenty. I'm running totally old school though, no O2 sensors or cats or anything. If I can remember I will try to record it tonight when I get home, should have it up by tomorrow.
Car: 91 camaro rs
Engine: 305 tbi
I don't, it sounds very similar to the example that they put up on their website though for the "Thrush Welded Mufflers"
Car: 1983 Z28
Here's what mine sounds like. It is idling a little lower than usual in Park because it wasn't warmed up. I didn't have a good place to put the camera in order to hear it while it was in Drive but you get the idea.
That buzzing that you hear is my fuel pump (holley blue pump) lol.
https://www.youtube.com/watch?v=YSBq...ature=youtu.be
Car: 1983 Z28
FYI typically my idle is at about 950 in Park, and between 650-675 in Drive.
In the Video it was idling at about 750 (since it wasn't warmed up).
I never realized how loud that fuel pump was though, haha.
Car: 88GTA
Engine: 5.7TPI
Car: 1983 Z28
Car: 1983 Z28
He's building it into a mud/rally racer
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I have a single thrush welded 2.5 inch in/out in the catcon area with 2.5 inch pipe from the turbo to right next to/just below the driveshaft. Terminates before the rear axle, but doesn't come past the back of the side windows. So where I live its technically not legal. But there is nothing but mud trucks running open headers by me so you can see why it doesn't really matter.
You can see in the last pic, it doesn't hang down at all past the ground fx. I also welded a bolt to the muffler and reused the catcon bracket to hold the muffler up. Works great. Though I do have a turbo, so your pipe routing may have to be different.
Car: 91 camaro rs
Engine: 305 tbi
I'm working on my exhaust install right now it's hedman longtubes 2.5 inch pipe dual thrush welded mufflers dumped at the axle. I can't figure out how to post pics though on this site
Car: 1983 Z28
Car: 91 camaro rs
Engine: 305 tbi
Car: 1983 Z28
Car: 89 RS "v6" sleeper named Suzie
Engine: 383 4bolt carbed
Transmission: WC T5
Axle/Gears: LS1-3.42 posi
Transmission: WC T5
A "little" ruffed up from being slammed, but you get the jist. Homemade in driveway on Jackstands.
Car: 88 IROC-Z
That is the worst exhaust and welding iv ever seen.
Car: 1983 Z28
Car: 88 IROC-Z
Transmission: WC T5
i made mine for free, did you? ask for advice then wanna be a dick, figure it out on your own then. btw i welded that bitch with a car battery and coat hanger. so now you know that id say thats some badass welding.
Car: 88 IROC-Z
Nothing "personal" man but, that is actual the worst iv seen, even by "thirdgen" standards.
I started this thread in June, its now September. The title says "...muffler mounted -in front- of the rear end". Not pointed out the side from under the "cat hump".
(the hump in the floor)
-nothing personal guy
Transmission: WC T5
No, I paid money for quality parts with quality work done to them. Did you?
Car: 88 IROC-Z
Car: 1989 Camaro RS
Engine: 5.0 305 V8
Transmission: 5 Spd
Axle/Gears: Unknown
If you want to see the worst exhaust on a thirdgen I'll post a pic of what the PO did to my car lol.
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
3 inch duals dumped with flowmaster race mufflers
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
