Good exhaust system?
Old Sep 22, 2014 | 10:36 AM
82z-28/92Rs's Avatar
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
I have a 92 RS with a hot 350 with shorty headers and 2 1/2 exhaust but its 1 pipe running to the cat then to the muffler that comes out duals but I dont like the sound or performance so what exhaust setup should I use? And I want it to be LOUD. 😈
Old Sep 22, 2014 | 11:21 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Good exhaust system?
You'll never get louder than uncapped longtube headers.
You can fab up a true dual system, alot of us have them. I have true dual 2.5 " pipes coming out of hedman longtubes, dumped before the rear axle. You just have to be more wary of speedbumps and other things if you go this route as it will cut down on your ground clearance.
Old Sep 22, 2014 | 03:00 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Any mufflers or just straight pipes and how will straight pipes effect performance?
Old Sep 22, 2014 | 03:05 PM
Car: 1983 Z28
Two thrush welded mufflers, see attached pics. Straight pipes won't affect performance (think of a permanent cut-out). My set-up is PLENTY loud though, I had the headers uncapped for a while with turndowns coming off the collectors before but the floor pans can get pretty hot, haha!
Attached Thumbnails Good exhaust system?-rsz_sd531740.jpg   Good exhaust system?-rsz_sd531745.jpg   Good exhaust system?-rsz_sd531738.jpg
Old Sep 22, 2014 | 04:56 PM
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
You should use a "x" or "h" pipe. It helped my dads motor alot. And is thrush one kind of muffler or r there differnt "series" like flowmasters? And any chance you got a video of that thing runnin? Id like to hear it.
Old Sep 22, 2014 | 09:20 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Mufflex.
Old Sep 23, 2014 | 06:05 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Go out and measure how much room there is between the ground and the transmission crossmember, and then subtract the diameter of the dual exhaust pipe you're using. You sure you're comfortable with that?
Any car with 2.90 rear gears definitely isn't fast enough to warrant halving the ground clearance. You can do loud with a single.
This is my setup, but understand that I have a special crossmember that allows me to tuck my pipes up into the transmission tunnel.
Get an engine with decent compression, some decent shorties, a 3" catback and it'll be plenty loud.
Mine is a 3.5" system, and I havent figured out a way to keep these quiet yet.
Old Sep 23, 2014 | 07:22 AM
Car: 1983 Z28
I've heard X pipes quiet it down a bit. They have different mufflers, but the name of this one is literally called "Thrush Welded". They also have Thrust Turbo, Glasspack, etc etc.
Here's a video, this was a cold start but you get the idea. I plan to shoot a better one eventually.
Old Sep 23, 2014 | 07:25 AM
sheikss's Avatar
I know on my 4th gen, the mufflex tucked way better than my duals. My duals were tucked better than 95% of the duals on 4th gens. They ran to the rearend and stopped.I will get the 4" on my gta tucked just as good. The duals were louder cruising down the highway and during idle, not by much though. Wide open throttle they were equally loud. I actually perfer the single 4" sound over the duals. I have 3 f-bodies, all have single 4" systems with longtubes.
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
makaveli09
Aug 12, 2015 09:07 PM
mustangman65_79
Aug 7, 2015 09:55 PM
