Need help identifying headers/y-pipe.
Old Oct 2, 2014 | 12:53 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Hello Thirdgen.org, I have an 85 IROC that the PO put Hooker Supercomp headers on, and my y-pipe decided that it loved the Michigan salt just a little bit too much and now needs replacing.
I'm having a hard time locating a replacement for this car, the only thing I know is that on my drivers side headers there is a plate that says "Hooker Supercomp".
It's a 2-bolt flange style, and I'm having a super hard time locating a replacement y-pipe for it.
Here's what I'm dealing with right now: http://imgur.com/fz0KqYH (and why I need a new y-pipe). I took it down the street to my local exhaust repair shop and they said they can't touch it unless I get a replacement y-pipe. They said I might be able to get away with using a band clamp but it's not recommended.
If anyone can help me with a part number or a URL to purchase a replacement y-pipe I would be deeply grateful.
Thank you very much for your time and assistance.
Edit: After doing some research, I believe they are 2055's.. meaning I might be SOL when trying to locate just a y-pipe. Does anyone know where to locate a replacement?
Edit 2: http://imgur.com/qMFqutO band clamp was so far a success.. will need to drive it for a while and see how it holds up so I'm not in a big rush to get a replacement y-pipe as of now.
Old Oct 3, 2014 | 04:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Need help identifying headers/y-pipe.
Are they short or long tube headers?
Old Oct 3, 2014 | 11:52 PM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Can't you measure the OD of the pipe, and get a section of pipe from the auto parts store that fits it and secure it together with exhaust clamps? Other areas of the header will rust away eventually, but it should be good for a few more years.
Edit, that should work. When you said band clamp I was thinking of something narrower.
Old Oct 4, 2014 | 06:19 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
They're shorties, the band clamp is holding up though. I'm pretty sure they're 2055's which are kind of common.
Old Oct 4, 2014 | 03:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Took a quick look at Summit and found the 2055 shorties with a Y-pipe (would assume Hooker pipe)..but didn't look for a separate Y-pipe...but might want to call them, ask if the headers will bolt up to the stock Y pipe without mods...reason I say this, is then you might have the option of finding stock Ypipe, or getting the Hooker pipe.
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
Tweeks25
Sep 17, 2015 08:04 AM
abrilnelson89
Sep 16, 2015 02:19 PM
angel2794
Sep 8, 2015 06:22 PM
