what headers and exhaust setup for best performance?
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
350 bored .60 over with flattop pistons, 041X 64cc heads (compression ratio???)with 2.02 1.6 ss valves. 272TL-6 comp cam and performer intake and quickfuel 750DP carb. Only gonna turn 6500 rpms max but would I need to use longtube headers or would my shortys do the same? And are longtubes louder than shortys?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: what headers and exhaust setup for best performance?
Shorties will fit better.
Auto or manual?
3" catback will be fun unless you're pushing 450hp+.
Auto or manual?
Car: 82 Z-28
Engine: built 350
Transmission: TH350
Axle/Gears: 2.90
Car: 1984 Trans Am
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
I just installed hooker longtubes and had to do quite a bit to make them fit. Hooker has really slacked off on quality control. Personally, I will never waste my money on shorties. If I am going to do headers then it is longtubes or nothing. Matter of fact, all my vehicles have longtube headers. No matter what you decide, make sure you have a good y pipe setup. Stay away from crossflow mufflers if you are looking for the best flow possible.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
I run hooker long tubes with a custom fab 2.5 inch exhaust through dynomax bullets. Yes I lost ground clearance but in 15 min I can have an open header car.
Don't rake to much to fit. Trim the k member on drivers side and rebemd some brake lines.
Strange, my driver side fit without problems clearance wise. It was close but would have been fine I think.
Engine: 383
I had to notch the k member right by the control arm mount then move the brake line for the rf wheel. Both headers rubbed on it. That could be from running the old original motor mounts tho.
Street Lethal
Apr 30, 2019 12:14 PM
evilstuie
Feb 28, 2016 03:33 PM
