4 inch muffler choice
Old Mar 3, 2015 | 08:32 AM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
I am about to start my exhaust build as soon as my trans is back from getting built. I'm researching mufflers and I'm looking at diesel mufflers as I havnt found much other than racing type mufflers. Has anyone used a diesel muffler in their build? I have 1 3/4 long tube headers and will make a 3 inch y to 4 inch single pipe. I'm looking for a good exhaust note but not too loud or raspy. The car is not a daily driver but a mix of street strip duty with some road trips along the way. I have read many threads and I'm not sure which mufflers I will be using any input is appreciated thanks.
Old Mar 3, 2015 | 08:48 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Re: 4 inch muffler choice
http://www.spintechmufflers.com/muff...r/cat_169.html
Old Mar 3, 2015 | 09:22 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I use mbrp diesel in mine. Sounds good, can fit 30" long in stock location
Dynomax ultraflo round 6" case in 4" dia and 16" long makes for a good muffler. Good noise reduction but if behind a hot motor like a 11:1 383 making 500 hp it still gonna be loud
Old Mar 3, 2015 | 09:38 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
http://www.magnaflow.com/02product/d...rtnumber=12770
I used this and mounted it where the stock muffler sat and then single 4" out.
LOVE IT! Much quieter than 2 3" Flowmaster mufflers, but screams at WOT
Old Mar 3, 2015 | 04:33 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Hooker maxflow
Idle and part trottle is deep rumble cruising around town not loud at all or obnoxious
But when you want to wake up the neighbors and or show that ford or dodge or Honda what's the deal WOT screams im all about business and Chevy devil knocking on your rear end lol
Think perfect for street due to quiet idle and part throttle but good nice loud WOT tone as I don't want to sound like I'm going WOT all the time like a mufflex , low key and or loud when needed
Old Mar 3, 2015 | 09:49 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I have a spintech and it is the best sounding muffler I have ever owned of any size. Not too loud and no annoying drone noise at a particular rpm like a lot of them have.
Old Mar 3, 2015 | 09:54 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Flow master!
Summit Racing Part Number:FLO-954056
Old Mar 3, 2015 | 10:05 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Another vote for the hooker maxflow muffler. It is hard to beat for the price. The only downside is that it is aluminized and not stainless, but very mild at idle, and opens up pretty good at WOT. I also ran a bullet muffler before the axle to prevent any drone as I was running ls manifolds at the time. I posted a video in other 4inch exhaust thread below this one.
Old Mar 4, 2015 | 08:46 PM
ransam's Avatar
Thanks for the ideas. So far I'm liking the hooker max flow
Old Mar 4, 2015 | 11:17 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Get it I have one I love it
Not the typical flow master tone
Old Mar 5, 2015 | 07:52 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Hooker LT, with custom 4" exhaust and magnaflow mounted in the stock location...
Old Mar 5, 2015 | 04:43 PM
Cosmik Debris's Avatar
Originally Posted by NufNuffZ28
Supercharged iroc 4" custom exhaust - YouTube
Is that the straight through 4" Magnaflow?
Old Mar 6, 2015 | 09:37 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes, but it quieted it a LOT!
Sorry for the smoke. Last video before I pulled the engine because I had a hole in teh piston!
Old Mar 8, 2015 | 03:02 PM
25thannivZ28's Avatar
Car: 1992 Z28 Camaro w/70k
Engine: 427 w/4" Mufflex Exhaust
Transmission: 700R4 3500 stall
Axle/Gears: 4.10:1
Hooker LT, mufflex y pipe (dual 3's into a single 4") MagnaFlow race muffler. Straight through no cat
Old Mar 8, 2015 | 09:06 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
First video ignore the other video as those videos of me driving are open y pipe
Old Mar 9, 2015 | 06:31 AM
Nonwoven29's Avatar
Car: 1986 Iroc z28
Engine: 5.0
Originally Posted by Zach/90\irocZ
March 8, 2015 - YouTube
Sorry for the off topic question. Was that your shift selonoids taking a crap? It did a very similar delay in shifting with my 4l60e when they where on there way out.
Old Mar 9, 2015 | 01:28 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
I don't know I was thinking 3-4 clutches it's a fresh build its not a delay my only issue is 3-4 shift just revs up and when I lift it shift and Rpms are way high so I think 3-4 clutch slipping bad
Pm me don't want to distract from thread
FormulasOnly
Jul 23, 2018 08:47 AM
gixxer92
May 18, 2017 11:20 AM
raymondandretti
Sep 27, 2015 06:43 PM
monte87cortez
Sep 26, 2015 08:10 PM
JSDaddy189
Sep 26, 2015 03:50 PM
