swapping a single cat for a dual, is it legal ??
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
mine is a 305 TBI I have heard that running dual cats in place of a single will increase HP is this true. Will a dual cat system improve my chances of passing a smog test lessen them?? Is installing a dual cat system on a 305 TBI a waste of time? My car is a 91' Camaro is it legal to swap a single for a dual?
Mark
Mark
Transmission: 4L80E/4L80E
Technically, to be legal, it must have been offered on the car with the engine/equipment you have, or be a CARB-certified replacement. Since dual cats were never offered on LO3's, and nobody offers a "certified" dual cat replacement for the LO3, technically, it isn't legal. But, I doubt you'd get pinged for having them.
As to being worth it, the factory system is a good place to look for improvement, but a single 3" cat should be more than adequate for all but the most wildly modified TBI engines. Same legal technicality as above.
Car: '87 Z
Engine: 355 in the works
I'm just wondering but... how is having dual cats better than having a single cat? I'd think that it would be more restrictive...
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
For the same reason why dual exhaust is better (more or less) than single exhaust. Four cylinders flowing thru 2.25" pipe is less restrictive than eight cylinders flowing thru 2.75" pipe. Plus each cat only has to clean up half as many cylinders too. But as was said above, you can only switch on TPI engines, as carb/tbi was never offered with dual cats. I remember Tom Keliher getting hassled by a clueless smog tech, when the tech's book said dual cats didnt come on Tom's 89 Formula 350. The book was wrong.
Car: '87 Z
Ok, I'm not sure if this is how it is but, isn't it one cat right after another? Or does the exhaust do some kind of y into 2 cats, then y back down to one pipe again? Can u post a pic or sumthing? I've never really understood this dual cat thing, and I'm ready to learn so...
I don't know where U R from, but in CT it is illegal to remove ANY working cat from a vehicle. I guess the only way you can get away with it legaly in CT is if you were to fail emissions with the present one.
Car: '87 Z
Ok, people always take 'remove' so literally. To me it means 'Remove and never put one back on'. Example: Say the cat goes bad, you have to remove the bad cat to put a new one on right??? So is it illegal to remove the cat in that case? More than likely not.
Car: '87 Z
I just found a pic of a dualcat setup, so can I put the dual cat setup on a '87 Z28 305 TPI??? This has sparked my interest. It looks like it makes the 3rd gens that much closer to dual exhaust
Would I need a new Y pipe or nething? Problem is, if I got the dual cat setup, I wasted 300$ on the flowmaster catback I have waiting to go on... What do you guys think I should do, and would it fit on my car?
Would I need a new Y pipe or nething? Problem is, if I got the dual cat setup, I wasted 300$ on the flowmaster catback I have waiting to go on... What do you guys think I should do, and would it fit on my car? Joined: Jul 1999
Car: '90 Iroc
Transmission: 5 spd
I'm thinking about doing this too, only because I may get a good deal on a set of dual cat headers. My question is how do you route the A.I.R. tubes? Right now there's just one going from the cat. into the engine bay, but how do you incorporate that second tube from the second cat. into the whole system? I also thought I heard once before that you need a 1LE heat shield for the second cat or something. Does anyone know about this?
Has anyone actually performed this change before?
Just to comment on the remarks about price and AIR tubes, if i were to do dual cats, i would put on dual cat headers/y-pipe, then use random technology cats(which flow as well as modern day cats found on brand new cars, that have no restriction and don't require AIR), then through the catbaack of my choosing. I would think that just switching to a random tech single cat would be more beneficial than putting all of the money into dual crap cats. Random techs may cost more, but the $230-250 for one 3" is cheaper than converting to dual cats.
Hmmm....I have dual cat 305, and it has a STOCK 3" intermediate pipe...
GMs conversion kit for the carbed 3rd gens includes dual cats and carries smog exemtion numbers for all fifty states. so they should be legal as long as you have the automatic trans. Same with 350 and carb
And what that would have to do with a TBI LO3 would be...
My 1 cat to 2 cat conversion.
When I did my exhaust I went to true dual 2.5" exhaust. I had to take my inspection sticker/city sticker/base sticker off (carefully) and had AAA tow it to the exhaust shop. I told them it was a wierd SCCA class that demanded 2.5" max exhaust with cats. They did it for me. Some more details and pics are in this link towards the bottom.
https://www.thirdgen.org/techbb2/sho...threadid=73181
Brinkkl2000
Aug 4, 2018 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
53, california, cat, cats, dual, exhaust, headers, installing, legal, random, single, swap, technology, thirdgen, ypipe
