do dual cats really help??
Old Jan 6, 2016 | 09:29 AM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
Just built a 383 TPI. 10:1 compression, comp 268 xfi cam, ARF 195 heads, comp pro magnum 1.6 rockers, edelbrock base, Arizona spped and marine runners, ported plenum.
I plan to use Dyno Don headers, but can't decide between 1 or 2 cat converters. Common sense says 2 will flow better and when GM adds 2 on the stock l98 I think it picks up 10 hp.
However, after the converters it goes into one 2.5" pipe, into a flowmaster muffler, and to stock dual tailpipes. Can dual converters really help given the rest of the exhaust system? Anybody ever checked/verified?
Ive read through some threads but cannt seem to find a good answer.
My thought is that one converter will flow as much as the rest of the exhaust system if capable of; but I'm just not sure. "
Old Jan 6, 2016 | 10:31 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: do dual cats really help??
Cat converters are bottlenecks. Having two of them will allow a more free flowing exhaust, even when they go back into a single pipe.
That being said, I'm converting my dual cat setup to a true dual exhaust by having my muffler guy run 2x pipes from the cats to 2x independent mufflers in the back.
Old Jan 6, 2016 | 10:49 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
"However, after the converters it goes into one 2.5" pipe"
It should go into a minimum 3" pipe to the rear.
Old Jan 6, 2016 | 02:39 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
is there any downside (besides the extra cost) to dual cats? also, any idea if I need a different size heat shield? (I have looked but cannot find any info on the heat shield)
Old Jan 6, 2016 | 03:11 PM
Dyno Don's Avatar
I never changed the heat shield, the one there seems to be fine.
Remember a 383 flows more air so a dual system is a must. IMO
Old Jan 6, 2016 | 06:11 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
makes sense. That's what I'll do.
Old Jan 7, 2016 | 05:57 AM
83 Crossfire TA's Avatar
the stock setup goes into a single 2.75" pipe that necks down to 2.5" on the inlet of the muffler (loosing a 1/4" that far back in the exhaust won't make that big a difference). Nothing came stock with a 3" pipe...
Old Jan 7, 2016 | 06:05 AM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
ok. Then am I ok to leave the exhaust alone from the intermediate pipe back? I heard the flowmaster robs some power, but...it's already there and in good shape....
Old Jan 7, 2016 | 08:53 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Have a look at the Firehawk exhaust setup. This should help find a starting point in exhaust design.
Old Jan 8, 2016 | 09:36 AM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
that is a great idea!
I just looked and can't find any pics on here; any suggestions on where else to look? (I googled too and all I get are tail pipe pics)
Old Jan 8, 2016 | 10:04 AM
LiquidBlue's Avatar
Transmission: MD8
If I run into info, I'll get back. Personally, I would avoid a dual exhaust on these cars due to the way the under body is designed. Seems like I've read 3" pipe is plenty big to handle up to X horsepower, which is a bunch. The Firehawk used headers, had N10 option, 3" cat back and probably other goodies. If you want to get really fancy, you could have a computer open up your muffler when pedal is detected to be on floor so that the exhaust just spills out the 3" pipe. If you're racing the 1/4 mile, it only needs to be open about 13 seconds or less
http://www.hotrod.com/cars/featured/...tiac-firehawk/
Old Jan 8, 2016 | 10:07 AM
LiquidBlue's Avatar
Transmission: MD8
Oh, here's a good one, the girl if nothing else!
http://thethrottle.com/2014/02/05/on...awk-31-photos/
Old Jan 8, 2016 | 04:47 PM
91 zeee's Avatar
Car: 1991 Z-28
Engine: 383 TPI
damn. that's nice! (oh, and the cars were ok too....)
Old Jan 8, 2016 | 08:39 PM
LiquidBlue's Avatar
Transmission: MD8
fer sur!
Old Jan 14, 2016 | 03:06 PM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
The chart I saw said 3" is good up to about 360HP. I don't really know if that's WHP or FWHP though. That's way more than any near stock motor will put out either way.
Old Mar 8, 2017 | 03:50 PM
jczoka's Avatar
Car: 1991 Z28 5spd
I'm thinking of adding a factory style dual cat to my 91 Z28.
The unknown for me is if the dual cat setup uses a different heat shield on the car body side. My single cat shield looks kinda small and wouldn't cover the 2nd cat.
Does anyone have a pic or info about the shield on a factory N10 car?
Old Mar 8, 2017 | 07:57 PM
Don't waste your effort.
A FACTORY dual cat setup is better than a FACTORY single cat one. Doesn't say a damn thing about AFTERMARKET ones.
If your car has the single cat now, just get the best single cat you conveniently can, and the best cat-back. It'll be VASTLY superior to the FACTORY dual cat stuff.
Old Mar 8, 2017 | 08:22 PM
Drew's Avatar
The dual cat cars have a heat shield roughly the size of Texas. I'm not sure it'd matter with aftermarket cats, they should have built on heat shields. The single heat shield doesn't do much good when the stock single cat fails and glows red hot, even with the shield the carpet melts to the floor.
Generally speaking, I'd personally run the dual cat setup if you have it available to you. The OE cats won't be much good after 25 years. The stock setup also has a less than ideal Y-pipe after the cats. But I still think the benefit is worth working around those problems. To most people it probably wont matter much either way.
Jdinmd
Feb 16, 2016 06:22 PM
gta_knight
Jan 26, 2016 12:29 PM
Buickstaged
Jan 7, 2016 05:31 PM
Procharged GTA
Jan 7, 2016 01:11 AM
BADNBLK
LSX and LTX Parts
Jan 6, 2016 12:43 PM
