How much ground clearance does everyone have??
Old Dec 22, 2001 | 11:21 PM
sslee's Avatar
How much clearance does everyones exhaust have to the ground?
Old Dec 23, 2001 | 06:34 PM
Z28DJP1987's Avatar
Very little, 6" or less.
Old Dec 24, 2001 | 12:41 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I have about 4 inches. 6 inches under the HUGE exhaust, but 4 under the TCI tranny pan.
Old Dec 24, 2001 | 02:24 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
wish i had 4 inches. mine is about two lol. bottoms out alot. i just took out the pass seat and some other stuff and it is a little more roomy underneath well except when i sit my fat *** in it.
Old Dec 24, 2001 | 06:47 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
George
Not much - about 4 inches.
Old Dec 24, 2001 | 07:07 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
I have about 4-5 inches
Old Dec 24, 2001 | 07:15 PM
breathment's Avatar
im not exactly sure how much i have, but the lowest part on my car is the cat back, it seems to hang lower then it should..
Old Dec 25, 2001 | 12:30 AM
HrdRockA4305's Avatar
About 6" at the CAT. Not a whole lot more everywhere else!
These cars are so freakin low stock... i can't hardly crawl under the front at all, and I'm not a real big guy. 5'11 155 lbs... you'd think my skinny butt could fit under the car but no. Just as another reference, buddy of mine has a 96 mustang thats lowered 2" and has a "stalker" front clip (added after he hit a deer, might as well upgrade instead of just replace, it was cheaper anyway) and his car and mine sit the same height at the rocker panels almost exactly. Theres also only about an inch or so of room when I goto a place with a "pit" that you drive your car over instead of having a lift. If I lowered the car i wouldn't clear the rails around the edges!
Old Dec 25, 2001 | 03:44 AM
rezinn's Avatar
Not enough, my borla hangs pretty low.
Old Dec 26, 2001 | 06:48 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I'd say about 4-6 inches, lowest point is where my I-pipe runs. Right now I can barely get the car on ramps without using a ladder. I do have just enough clearance to slide a hydraulic jack underneath when I need to raise it. Getting the SFC's installed was great since now I can use any point along the SFC to lift the car.
Old Dec 26, 2001 | 05:22 PM
Steve86TA's Avatar
Car: To many to list
Less than 2 inches at the Cat.
Old Jan 1, 2002 | 08:38 PM
Gta-Paladin's Avatar
A slim 4 inches
Old Jan 1, 2002 | 08:45 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
4" w/true duals.
Old Jan 3, 2002 | 09:25 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
About 2"s at the turn downs that are before the rear diff. And thats with my air shocks!!
Old Jan 4, 2002 | 02:18 AM
Jza's Avatar
Jza
'bout 3-4 inches at the lowest point. If I twist my head just so, dislocate my shoulder and jaw, and crawl around at a certain point, I still can't fit under the car and I hurt a lot.
Old Jan 4, 2002 | 02:28 AM
87transam5.7tpi's Avatar
I'd say I have about 6" + the 3" catback I put on actually fits better than the stock 2.5" pipe I used to have.
Old Jan 4, 2002 | 02:43 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My lowest part is the cat. I think I could fit half a pop can under it
Old Jan 4, 2002 | 11:26 AM
ATOMonkey's Avatar
I don't know how much I have yet since my system in laying on the ground, but I have to get someone to lift on the fender to get a low profile jack under the highest part. There is no way it's more than 4" at the frame. That's with new springs, but I think the 4 Bolt truck block I have is a little more than they were designed for.
Old Jan 7, 2002 | 01:04 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
under two inches at the cat and the cutout, with the car dropped two inches
$750 L98
Feb 1, 2025 02:25 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Thaney9
Oct 24, 2015 07:26 PM
91 SrS
Oct 7, 2015 04:32 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
