TPI Manifolds.
Old Dec 20, 2017 | 08:13 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
TPI Manifolds.
Would the 305 TPI manifolds for an 87-88 car be the same as the 350 TPI manifolds? I know the TBI manifolds/ y-pipe aren't the same.
Old Dec 25, 2017 | 01:55 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: TPI Manifolds.
They are the same.
Old Dec 26, 2017 | 07:46 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
Thanks I thought so
Old Feb 7, 2018 | 11:53 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
What size pipe plugs replace the AIR Tubes I'm removing? Ive done it before and used to know but I just don't remember.
Old Feb 7, 2018 | 11:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Manifolds.
https://www.thirdgen.org/forums/exha...smog-pipe.html
Old Feb 7, 2018 | 12:17 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
Thanks man.
Old Feb 7, 2018 | 12:19 PM
Drew's Avatar
Re: TPI Manifolds.
An inverted flare plug will seal on the flange the old AIR pipes sealed on. A pipe plug will try to seal the threads, and has 'worked' for some people. I've used both at one point or another, and the flare fittings fit a lot better, and seal better.
A true pimp just cuts the AIR pipe flush against the existing nut with a hacksaw, and then welds the damn thing closed. Flawless Victory!
Old Feb 7, 2018 | 01:32 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
I used the brass plugs a few times with some RTV never had issues. Stripped a bolt out to my smog pump though it may put a halt to my plans for now. Not a lil stripped either, totally stripped.
Old Feb 7, 2018 | 01:52 PM
Engine: Lb9
Transmission: M20
Re: TPI Manifolds.
Post #59 has a air pump for sale. What do you need a air pump if your deleting the air tubes ?
https://www.thirdgen.org/forums/tpi/...-350tpi-2.html
Old Feb 7, 2018 | 02:02 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
Its coming out.. eventually. Stripped one the bolts trying to take off the air pump so I just tightened the other back down for now to let my knuckle heal and cease the cursing. Lol. I have a delete pulley to go back in place of the air pump when I do remove it. Also plan to switch to TPI manifolds and Magnaflow y-pipe if everything works out and I have time.
Old Feb 12, 2018 | 03:23 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: TPI Manifolds.
If I remember correctly there is a spacer between the y-pipe and exhaust manifold on the TPI exhaust. If I order a magnaflow y-pipe will I need this spacer? Is this spacer something a muffler shop would keep in stock for maybe other applications or do I need to track one down?
Old Feb 12, 2018 | 03:55 PM
Drew's Avatar
Re: TPI Manifolds.
You'll need to track one down. It's not a typical exhaust donut, it's basically the EFE flapper housing without the flapper. The right one has "HO" cast into it, a couple ears to locate it between the studs, etc. You probably have the same kind of thing with the low output manifolds. Might be able to just bore it out a bit to make it match the manifold.
NightHawk1824
Feb 17, 2013 12:26 PM
.JLC.
Apr 19, 2012 08:55 AM
Blownz28man
LSX and LTX Parts
Oct 8, 2011 07:11 PM
