Headers and y pipe to fit t5
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
I know there are clearance issues with header/y pipe with a t5. So what combos are out there that is known to fit around the slave cylinder and such on a t5 car. Thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Headers and y pipe to fit t5
Not a problem with shorty's
Car: 86 Trans am
Engine: LG4
I've had Edelbrock and SLP in my car. Both fit fine. The SLPs fit a T-56 as well.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
If you can cut and weld, you can make long tubes fit. I've got Hooker 2210s on my IROC with a Tremec TKO600 trans. They fit pretty decent. My dad has Hedman long tubes on his car, the collector hit the slave mount, but he cut the collector off, slid it forward, angled it down slightly and all is well.
I will say however, that if you're making 450hp or less, just go with the Dyno Don shorties. Way easier, way less work and better ground clearance.
KnightmareCS
Jan 24, 2016 07:38 AM
