Stock Muffler and Tailpipe Recommendation
Old Apr 9, 2019 | 05:14 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
For my stock LB9 IROC, looking at the Walker SoundFX muffler for an OEM sound and also want mandrel bent, OEM looking tailpipes. Any recommendations?
Old Apr 9, 2019 | 05:16 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Stock Muffler and Tailpipe Recommendation
This may or may not be the same guy I got the mufflers from previously. Don't know. But another TGO member PM'd me this. Figured I'd share it with the community. Good luck!
https://www.kijiji.ca/v-other-auto-p...ationFlag=true
Old Apr 9, 2019 | 05:19 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
I have the Walker SoundFX Cat Back on one of my ThirGen's... If you're looking for the pur of a kitten get the Walker SoundFx. If you're looking for the growl of a lion... get something else.
Old Apr 9, 2019 | 09:08 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
would a NOS SLP 2OTL interest you?
Old Apr 10, 2019 | 11:46 AM
Engine: 350 TPI L98
Transmission: WC T5
No, thanks though.
Old Apr 10, 2019 | 01:44 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
These Tailpipes look pretty stock.. I was looking at swapping out my straight pipes with these..
https://www.summitracing.com/parts/a...iABEgKLIPD_BwE
https://www.summitracing.com/parts/aph-x3001/?rrec=true
I know the Walker muffler is what a lot of guys use for OEM replacement for our cars..
Old Apr 10, 2019 | 03:31 PM
Drew's Avatar
For a stock style muffler, there are only so many options that really will replace the stock muffler exactly. Dynomax offers a 'Super Turbo', and an Ultra Flo(w?) that are pretty much drop in replacements. They also sell a Ultra Flo(w?) that up's the ante by being a true 3" in and dual 2.5" out. Why does that matter? Because a lot of 'stock replacement' mufflers are going to be a 2.5" in and dual 2.5" or 2.25" out. People like the just round up the size to the next number that sounds good and logical, but if you measure things the stock "Good" intermediate pipe is 2.75" necking down to 2.5" where it slips inside the muffler.
A lot of the replacement mufflers marketed for thirdgens, whether they're part of a cat-back system or stand alone, are going to be a random size inlet/outlet, and this part that bugs me - the case is often considerably shorter. No big deal, you just grab a dozen exhaust pipe cut-offs from the scrap bin and extend your tips and intermediate pipe until everything reaches. And if a super picky soul like myself or some of the History/Originality nerds peeks under and sees all the welds and couplers, we're likely to lose a lunch.
Another thought on the Walker/Dynomax line-up... Pretty much everything below the Super Turbo is going to be quieter than stock. Even the Ultra Flo(seriously is there a W? Idk) is considered very quiet. Even without a cat they're quiet. Get into something like a Flowmaster and you get more noise and the same performance. Different brands and designs give different levels of noise. If you want to hear it at all, watch out for most of the stock replacement mufflers because they'll be quiet.
Old Apr 10, 2019 | 04:58 PM
Axle/Gears: G80 GU2
Good advice..
I like a Flowmaster or Magnaflow.. With a cat its not too loud but the idle is nice..
Old Apr 10, 2019 | 06:21 PM
Saxondale's Avatar
Car: 84 Z
IMG_4282.MOV
Walker Quiet Flow SS
About a minute after first start in 6 months.
Old Apr 10, 2019 | 06:35 PM
chazman's Avatar
Axle/Gears: BW 3.45
These are the closest thing to factory tail pipes.
[img]https://www.thirdgen.org/forums/atta...ps6csuwzjg.jpg
http://www.ebay.com/itm/301873320480...%3AMEBIDX%3AIT
http://www.ebay.com/itm/231846324013...%3AMEBIDX%3AIT
Well I guess the eBay links expired. They are made by Xcelerator and ordered from Carid https://www.carid.com
Old Apr 10, 2019 | 06:44 PM
Saxondale's Avatar
Car: 84 Z
I wish I'd have beveled mine before installing. Next time.
Old Apr 10, 2019 | 07:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
Check out my white convertible thread. There's a good discussion in there about it.
Old Apr 10, 2019 | 07:24 PM
Axle/Gears: G80 GU2
I think those are the same that I posted.. direct fit to the Xcelerator muffler..
Old Apr 10, 2019 | 07:25 PM
Axle/Gears: G80 GU2
Chaz’s tail pipes look great..
Old Apr 10, 2019 | 07:27 PM
chazman's Avatar
Axle/Gears: BW 3.45
Yup, those are them. If someone could combine those tail pipes with one of the OEM GM mufflers from my first link, it would take a sharp eye to tell it wasn't factory.
Old Apr 10, 2019 | 09:43 PM
Engine: 350 TPI L98
Transmission: WC T5
Thanks for all the advice. I went with a Walker 18375 SoundFX which is advertised as a drop in replacement and being the OEM sound (perforated inner tube muffler). For the tailpipes I went with the AP. Those bevel cuts are OEM.
Old Apr 10, 2019 | 10:00 PM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks Lots of measuring and fiddling.
Old Apr 10, 2019 | 10:03 PM
Engine: 350 TPI L98
Transmission: WC T5
looks great!
Old Apr 10, 2019 | 10:08 PM
Drew's Avatar
Depends on the tail pipes. Those AP exhaust tail pipes are close to 82-89-ish pipes. 91-92 pipes actually turn down.
The closer exhaust was what was left of the stock trash on my 86 TA. The further is the Walker Dynomax 2.75 intermediate pipe (46669?) with the stock muffler and tips from my 91 Formula. FWIW the muffler and pipes on my Formula now are from a 93-97 Formula or Trans Am, it's the same exact muffler but with slightly longer pipes and the Quad chrome or stainless tips. To be honest, the tucked turn downs on later thirdgens just give up a little too much pizzazz.
Old Apr 10, 2019 | 10:25 PM
gt4373's Avatar
Transmission: 5-Speed Manual
This Is My Factory Muffler,The AP Tailpipes Are The Best Factory Match.
chazman
Apr 5, 2012 03:38 PM
leeperryracing
Nov 19, 2007 09:15 PM
BigBadJap
Dec 16, 2004 11:06 AM
Tremo
Northern California
Sep 26, 2003 08:28 PM
Adams87Camaro
Aug 6, 2002 01:43 PM
