Need part # L69 I-pipe
Old May 1, 2019 | 12:30 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
Transmission: 5-Speed
Have a L69 with a 4th gen Gmmg on it, intermediate pipe blew a seam and was wondering if anyone could point me in the direction of a replacement piece if they make one available, it’s the pipe after the cat (4 bolt flange) that mates with the pipe going over the rear axle, can provide more pics if needed. Kinda new to working on exhaust, forgive me please.
Old May 1, 2019 | 12:36 PM
Drew's Avatar
Re: Need part # L69 I-pipe
That's going to be a tough find regardless where you go looking. The days of companies offering anything for thirdgen exhaust are long gone, much less something only used from 83-85. Probably be easier to cut the bad pipe off the flange, get a mandrel bent section of pipe (guessing a 45* angle section would come close) and weld it to your existing flange.
Old May 1, 2019 | 01:30 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Walker Shows It Their Catalog,But They Seem To Be Hard To Find.
http://www.walkerexhaust.com/catalog...g-lookup/47597
Old May 1, 2019 | 03:22 PM
Drew's Avatar
Walker/Dynomax has been cutting their thirdgen product line with a machete for a few years now. It's worth a try if you can find something in their catalog that suits your needs, but there's a strong possibility even if something is listed in the catalog that it may be discontinued or limited to existing inventory. Be careful ordering from anyplace that drop-ships from the manufacturer or lists the item on backorder, there's a real chance the inventory and production isn't really there to fulfill the order. You may want to take additional steps to CALL a vendor that may have the item available to verify if it is really available before firing off an online order and waiting for something that may never show up. In the past Summit has changed the expected ship date several times before finally switching an item's status to no longer available.
One other note on the Walker pipe. Usually the pipe is 2.75" and narrows down to 2.5" the last bit that slips inside the muffler, the same as stock. If you only need that short segment in your photo from the flange to where the intermediate pipe straightens out, it may or may not bother you.
Old May 1, 2019 | 03:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I had considered this one for my '85 a while back. It's an LB9 but the '85's used the L69 exhaust. I didn't go with it because it states 2.5" diameter when the factory piece was 2.75. But as Drew mentioned, it may be 2.75" and necks down to 2.5 when it inserts in the muffler. If so, that would be correct.
Old May 1, 2019 | 06:20 PM
85IrocHO's Avatar
Car: 85' IROC-Z
Engine: 5.0 HO L69
Thank you everyone for the reply, really I only need the short section between the flange and where the clamp is in the picture, assuming there is enough “healthy” pipe coming off the flange I’m considering just slipping new pipe over it and clamping it down, should I be using 3” for this?
Old May 2, 2019 | 12:06 PM
Drew's Avatar
Calipers and tape measures, and rulers... Harbor Freight has lots of them.
We can guess what you have on your car, or we can tell you what we have on our cars, or you can measure your car. I know, totally crazy, but one of these options is vastly more accurate.
Old May 3, 2019 | 09:19 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
That walker piece was indeed 2.5" from the cat flange all the way back. Put one on an 85 several years ago. That was when the I-pipe AND specific cat (with four bolt flange on both ends) were readily available.
a better plan today may be to use the fourth gen I-pipe that is truly 3" and has a slip fit connection to the cat and modify your existing y-pipe for a cat that is now available.
88 vert guy
Jul 24, 2016 08:35 AM
Flechette92
Dec 4, 2011 09:18 PM
'84TA w/L69
Oct 17, 2003 01:46 PM
Alan84TA
May 10, 2001 08:05 PM
Holland
Feb 25, 2001 08:14 PM
