A/C & Alt Support
Old Apr 30, 2023 | 09:17 PM
dmyruski's Avatar
Car: 92 Camaro Z28
A/C & Alt Support
I got a 92 TPI and just installed Flowtech Headers 16102FLT (no smog tubes) and I have 2 questions. I searched both but came up dry.
Q1: There is no room to install a studded bolt for the A/C & Alt Bracket. Are the supports really necessary and if so what have you guys done to remedy.
Q2: #5 Plug is impossible to get a socket on. I don't even think there is clearance for a shallow socket not that it would work. Is there a specialty socket out there or do I just have to fight it with the good ol wrench?
Thanks guys and thanks for reading, I truly appreciate any suggestions.
Old May 1, 2023 | 10:09 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: A/C & Alt Support
There are special spark plug sockets made for use on headers. They are short spark plug sockets. Check Summit. When I pull plugs on my TPI swapped 87 Monte Carlo SS, I have to use open end wrenches and sockets. Some of the plugs I have to get from under the car. Others, I have to remove the front wheels and access the plug from a hole I cut into the plastic wheel well. The hole cut into the plastic wheel well applies to plugs #8 and #7.
Old May 1, 2023 | 10:35 PM
NoEmissions84TA's Avatar
Old May 2, 2023 | 09:15 AM
dmyruski's Avatar
Car: 92 Camaro Z28
Thanks much, I'll look around on Amazon.
techno_1961
Feb 17, 2010 11:23 PM
AKATDOG
Mar 17, 2009 11:45 PM
chitowncruiser
Feb 2, 2003 09:42 AM
