do i nave to pull the engine
Old Feb 2, 2002 | 05:13 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
do i have to pull the engine up a little to put the edelbrock headers on. or the headmen headers.
Old Feb 2, 2002 | 05:38 PM
Ragin'87's Avatar
you don't have to "pull it up". At most, to get the passenger side in, you'll have to undo the passenger side motor mount, and use a jack and block of wood to tilt the motor on the driver's side mount. that should give you more than enough room to put in headmans to edelbrock headers. It took me less than an hour to do headmans after the 2nd time, and that's all I did. No need to actually pull the whole thing up.
Anthony
Old Feb 2, 2002 | 05:52 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
I have an 83...things just dropped right in..the hardest part was getting the x-over on.....i dont have a floor jack or stands...
rob
Old Feb 2, 2002 | 06:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You shouldent have to, although if you were to take the center bolts out of the mounts and raise the engine it would give you some extra room to work with.
SSC
Old Feb 3, 2002 | 09:35 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
On mine we didn't have to raise or move the motor at all. Just move things out the way to get the manifolds off, and the headers slid right in.
Old Feb 3, 2002 | 11:40 AM
Car: 84 camaro Z28
Engine: 434sbc
thanks for the imput guys. i was wondering if anyone knows how much it is to get headers coated with that ceramic stuff. see, i want to get the edelbrock headers but you can get them in black paint(which i don't want) or nickel/chrome plated. should i just get the chrome ones. i like the edelbrock one because they will work with the stock cat and comes with the y-pipe. anyone out there have the edelbrock headers. do have any complaints or problems with them. thanks alot
Old Feb 3, 2002 | 12:38 PM
Car: 1983 Z28 Clone
Transmission: TH350
well i wasnt going to get headers at all... then i went and was going to buy pacesetters...i thought hey better than stock...waited a little and bought TES.....non coated...IF YOU CAN AFFORD IT and your going to sink some good money into this car.. go ahead... I bought my car for 600 bucks and its a rust bucked that i fixed up and primered grey...looks like a beater..and its just a summer car sooo....i didnt get them coated...i've seen headers that werent coated and they ARE RUSTY!!!!!!!!!!....I just sanded off the black shipping paint and put a couple of light coats of 2500 degree crome paint on......then one good coat...i havent had the motor running soo i dont know ...it should last a while...i think i've seen some posts about guys using high temp paint with good results..............if i had enough money to get them coated I still wouldnt ...i would gotten uncoated and spent the rest on a cam or something..................
Pretty much................ It's all up to you...............
Rob
78 305
NON CC q-jet
NON CC dist.
416 heads 1.84"/1.5" valves, 58cc chambers
th350
performer intake
edelbrock open element
edelbrock TES 3"
3"catco cat
3.73 gears
digital tach
rear spring rubbers
Shift kit
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
