Y-Pipe?
Old Feb 10, 2002 | 12:51 AM
Justin88-305's Avatar
Y-Pipe?
Does say an Iroc Z or Z-28 have a bigger Y-Pipe than my 305? or am i stuck paying the 100+ dollars for one that some company such as Hooker or Hedman made?
Old Feb 10, 2002 | 02:23 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Considering 305s were also available on IROCs and Z28s I would say no. But get a second opinion. If you're getting headers you'll have to get a new one though.
Old Feb 10, 2002 | 07:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My 85 IROC is an LG4 305. The y-pipe is tiny! Check out my post LG4 Exhaust Pics. You'll see that the L69, which is the HO 305, was much larger.
James
Old Feb 10, 2002 | 10:32 AM
ImportsRsloths's Avatar
Hey Justin I just took the stock Y pipe off my 88 IROC Z TPI 5 speed its the big diameter one in good shape... you can have it for $50... i upgraded to these
Old Feb 10, 2002 | 10:34 AM
Oh yeah Half the reason am willing to sell you it is because you live in cincinnati ohio and thats where i live... how close do you live to the beechmont/eastgate area???
Old Feb 10, 2002 | 09:08 PM
I live in the eastgate area, about 5 min from the mall. We should get together sometime. oo and if i can get the $ together ill prob get that pipe from ya.
Old Feb 10, 2002 | 09:56 PM
Keith5's Avatar
Car: C1500
Another thing. You will probably need his manifolds too. The TPI ones are better(so I've heard) plus I'm not sure if your stock ones will work with his y-pipe.
Old Feb 10, 2002 | 10:08 PM
Im planning on getting headers from Heddman but i didnt wanna spend the extra 100$ for their y-pipe so i figured if those were bigger then id save myself some cash
Old Feb 10, 2002 | 10:11 PM
Keith5's Avatar
Car: C1500
Do the Heddman's fit the stock y-pipes? Or are you just going to get it modded to fit?
Old Feb 10, 2002 | 10:31 PM
Car: 99 Formula
Axle/Gears: 342
Whenever you get headers, you have to get a new y-pipe, or one that isn't designed for manifolds. I believe.
Old Feb 10, 2002 | 10:42 PM
87transam5.7tpi's Avatar
I've called hedman about their headers. they said that all of them will need a new y-pipe. the stock one won't fit.
Old Feb 15, 2002 | 06:30 AM
mark406's Avatar
i have the hedman headers..and y pipe..word of advice tho...the y pipe is in 2 peices...and you bolt part of the y pipe up to the drivers side header flange..then the pass side heaer flange..and the rest of the y pipe slips onto the drivers side y pipe thats bolted to teh headers...now..the key to get them to fit perfectly with no leaks...{i had to do this..i dont know if all are like this} is the smaller peice of the y pipe that bolts to the drivers side header..take a hacksaw..and cut about 7/16ths off the pipe..so that the other peice of the y pipe will fully slide onto that pipe..if not..it hits the inside of the pipe.and then you cant bolt up to the passneger side header.any of that make sense..lmao.my headers and y pipe are about 5 months old or so...and heres what they look like..no leaks at all tho..sounds great with 3 inch 40 series 2 chamber flows.no cat ov course
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
