Headers????
Old Mar 9, 2002 | 04:42 PM
1991Z28's Avatar
Headers????
I've noticed most everyone on this site seems to recomend headers...I've read about a late 80s Formula 350 in a mag. that they put SLP 3/4" headers on and a full exaust and only saw about .1 sec improvement. I've already got dual high flow cats and a 3in catback exaust...For those of you with headers: What kind of improvement have you seen? What kind do you have (primary size too)? Are they really worth it??? By the way, it's for a '91 Z28 350/auto. TIA
Old Mar 9, 2002 | 04:55 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Those hookers that I want will be worth it.
Old Mar 9, 2002 | 05:15 PM
87transam5.7tpi's Avatar
man if they only noticed a .1 improvement, that car wasn't running right and/or had a terrible driver in it. I'm not calling you a lyer,I belive that. but they should improve your car mroe than .1 sec.
Josh
Old Mar 9, 2002 | 05:40 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
they should give you more gain than that and i would go with 1 3/4" primaries
Old Mar 11, 2002 | 05:53 PM
1991Z28's Avatar
Any brand recommendations? I'd rather keep the AIR crap...I guess.
Old Mar 11, 2002 | 06:45 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you want 1 3/4" go with SLP or Arizona M&S, 1 5/8" Edelbrock TES. If you go with Edelbrock get them coated, they rust real quick, especially in the salt belt area up north.
Old Mar 12, 2002 | 12:46 PM
1991Z28's Avatar
Would 1 3/4" be better? I'd think they might hurt low end torque a little and help higher end hp. It's not like a TPI is hurting for torque in the first place, but which would you guys recommend for a 350: 1 3/4" or 1 5/8". Right now the engine's stock...and will probably remain so until I rebuild the whole thing (What's the point of heads and a cam type stuff on a 165K engine )
Old Mar 12, 2002 | 04:39 PM
Ricktpi's Avatar
1 5/8" for stock.
Old Mar 13, 2002 | 03:07 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
1 3/4 for 350
1 5/8 for 305
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
