Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
strut tower brace measurements
Old Mar 10, 2004 | 03:23 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
hey guys well i recently got access to welding equipment so i wanna make as much stuff for my car as possible, anyone have the mesurements on a stb for a carb'd 350 and a fuel injected 6?
thanks
Old Mar 10, 2004 | 05:53 AM
ede's Avatar
ede
sorry i don't have the measurements, i'd just pull a tape on my car.
Old Mar 10, 2004 | 07:52 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
best way is to measure for your exact car.
Old Mar 10, 2004 | 08:37 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright guys thats what i'll end up doing
Old Mar 10, 2004 | 09:44 AM
ede's Avatar
ede
after you get done you might want to ocme back and post any info you have for someone doing a search that comes across this thread.
Old Mar 10, 2004 | 09:13 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
for sure ,i'd love too i'll probably get around to it later this month as i'm working alot
Old Mar 11, 2004 | 08:02 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
I am also considering this, But Where should I measure from and to? And also What materials will be needed?
Old Mar 12, 2004 | 10:33 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
measure from the strut tower over to the other strut tower, you'll need some 1 inch round pipe or a peice of steel and possibly some brackets depending on how you want to set it up
Old Mar 14, 2004 | 11:28 PM
topless89rs's Avatar
Engine: 5.slow
heres a couple pics of the one i m ade. took me about an hour and a half-2 hours start to finish. i used 2/16 thick plate for the brackets and i used 1 inch square tubing for the rest.
Old Mar 14, 2004 | 11:29 PM
Engine: 5.slow
another...
Old Mar 14, 2004 | 11:31 PM
Engine: 5.slow
i need to pull it back off, clean it all up and paint it but its looknig good for now
Old Mar 15, 2004 | 12:32 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
did u bend it or cut and weld the two pieces for the long bar
Old Mar 15, 2004 | 11:41 AM
Engine: 5.slow
i tryed to bend it but i don't have a tubing bender and its too think to bend without one so i cut it bent it after the cut and welded it back up
Old Mar 15, 2004 | 12:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Would a tubular or square design be stronger?
Old Mar 15, 2004 | 08:02 PM
ss85tadude's Avatar
Car: 85 Trans Am
Is it better to bolt the STB to the brackets or make a soilid design? It seems like the bolts would start to get loose after a while.
Old Mar 16, 2004 | 07:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
all STBs are bolted....you need to be able to take it off too... lol.
Old Mar 16, 2004 | 07:47 PM
ss85tadude's Avatar
Car: 85 Trans Am
What I ment was, The brackets that you bolt on to the main STB brace ( The part that bolts onto the tower) is it better to bolted or welded. I know that if it was bolted then it wold be easier to fit.
I also have another question. How far should the brace sit above the plenum.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
