Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Throttle body "boot" questions
Old Mar 15, 2004 | 04:01 PM
kraftopia02's Avatar
Car: Firebird Pro/Am
Engine: Modified 350
Axle/Gears: 3.08 Posi
In the process of my motor swap, i did an A/C and SMOG pump delete, and in order to keep the belt routing the same i put a ribbed pulley on the tensioner and routed it as shown. The problem is i now have a cleanarance problem with the throttle body rubber "boot." Does anyone know of a boot that has a 45 degree or 90 degree bend right after it attaches to the TB, or any EASY way to fabricate one? I'm really tired of making custom parts, hehe, so an aftermarket product would be real nice.
Old Mar 17, 2004 | 11:46 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I made a steel bracket that sits between the belt and the intake boot, and keeps the boot off of the belt.
I hope that helps.
Troy
So Cal
Old Mar 17, 2004 | 11:52 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
LT1s have a 90* bend after the TB... that might be what you're looking for...
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
