Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Torque Arm Fab
Old Mar 28, 2004 | 03:49 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
Torque Arm Fab
started welding up some boxed steel pieces to an extra arm i had laying around. figured it would make the stocker more ridged. im too broke to get a cromoloy one, so this will have to do untill i get the money saved for the BMR piece. ill have another picture of it soon when its finished and painted. what do ya think? i still have 2 more boxed pieces to weld on the other side. the picture makes them look smaller then they really are
Old Mar 28, 2004 | 03:55 PM
onebinky's Avatar
That qualifies as my kind of mod: Cheap or free
Let us know how or if it improves traction, that's a really good idea.
Old Mar 28, 2004 | 05:26 PM
Kontrax's Avatar
Car: 86 Camaro
i looked at the arm again. im going ot leave it the way it is. its definetly going to be strong enough without adding the other 2 pieces. i plan on brushing it down with a knot brush on the angle grinder, and painting it. ill prob have a finished product by tuesday.
as for traction, i couldnt even tell you the gain i would aquire. i built my whole car up. started from a base berlinetta modle with the carbed 305. now i have a 362 and TONS of goodies under the hood and on the suspension and havent driven the car yet. so i wouldnt know the gain it gave because of all the other mods i have under the car. if you have an extra arm laying around you can send it to me and ill fab you one if you like. i have a lot of steel left to make plenty more. the boxed steel is solid BTW, not hollow. i thought i had an extra arm in the gurage, must have junked it when the guy came collecting steel for the junker. let me know
Old Mar 30, 2004 | 10:47 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I have an extra torque arm lying around. I knew I wanted to try and box it up somehow. Thanks for the pics. I will post some pics when I get mine boxed up too.
Old Mar 30, 2004 | 06:11 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
can u send us pics in other angles like top side front thanks
Old Mar 31, 2004 | 10:59 AM
caribbean 85's Avatar
Car: 1985 Berlinetta (drag only)
Engine: 383ci chevy
Transmission: TH-350 T-brake
Axle/Gears: 9 inch Ford & 4.56 gears
I like the idea - I was wondering who has done any home made fabs to the torque arm
I got some sections of plates welded in the inner grove 5- 6 inches apart to add strength overall (I hope)
Each plate is about 4 inches wide and they narrow with the torque arm as it nears the front
I haven't installed it yet -
The only issue worrying me is how close does it get to driveshaft in motion
I know I have clearance at rest but I wonder how much it moves in full flight inwards??
I will try and post pictures later
Old Mar 31, 2004 | 12:13 PM
onebinky's Avatar
*I think* It shouldn't move inwards under load unless it's distorting. It's only purpose in life is to prevent the differential housing from trying to turn the opposite direction of the wheels under tq load.
Thats why alot of the higher power thirdgens with stock tq arm and mount will shear the mount and thump the tq arm into the floorboards
Old Apr 1, 2004 | 07:30 AM
Kontrax's Avatar
Car: 86 Camaro
it clears the drive shaft. i have an extra rear end in the gurage i test fitted it to and it cleared just fine. ill try to get other angle shots soon
Old Apr 3, 2004 | 03:16 PM
Jester's Avatar
I thought about doing that for awhile myself. Eventually I concluded that the torque arm had enough significant design flaws that boxing wouldn't fix that it wasn't worth it. IE was too heavy already, wasn't adjustable, was mounted in a bad place, and a weak mounting point.
A much better fabrication project would be to make your own arm from scratch. I changed to that plan, got my design all worked out, but got lazy and bought a jegster arm
Old Apr 3, 2004 | 06:13 PM
Kontrax's Avatar
Car: 86 Camaro
no way. it stiffened it right up. the mounting location is fine, i wouldnt alter the mounting location. only arm i know that mounts in a different spot its the sphon arm and i heard they have some problems. theres a reason why the factory put the arm where it is. the arm realy isnt heavy... im sure the extra few pounds wont hurt, im not stright out racing it. pinion angle is really for strip i would think, i have a lot of buddies that race with the stock angle and do fine. they also use a stock arm. i think practical when doing things to my ride. no point in having a power house for a car(super loud exaust, huge cam etc..) thats intended for street use. eventually im going to get the BMR cromoly arm anyways, this is just to hold me off untill i get the money
Old Apr 6, 2004 | 08:46 PM
jocww's Avatar
how did kontrax get banned
Old Apr 6, 2004 | 08:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Jester,
why does your home page direct me to a **** website??
Old Apr 6, 2004 | 09:45 PM
onebinky's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=233271
Check this out, he sounds kinda like a cocky know-it-all that got showed
And jester, whats up with your website? It's some "freaks of nature" porno site Scary...
Old Apr 12, 2004 | 07:15 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i remember that thump all too well.. lol
Old Apr 15, 2004 | 07:56 PM
ljnowell's Avatar
How can someone who is banned still post? I just dont understand.
Old Apr 15, 2004 | 08:06 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
he hasnt been posting lately because he is banned.
Old Apr 15, 2004 | 08:08 PM
ljnowell's Avatar
i gotcha, had to look at dates. Sometimes my senses are dulled.
Old Apr 20, 2004 | 10:35 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
actually i hate to hack on the guys work, but what he did there will do absolutly nothing for strengthening the TA. all that will do is add weight to the car.
If anyone is considering this as an alternative to buying a aftermarket TA, your just wasting your time IMO.
Old Apr 20, 2004 | 10:58 PM
onebinky's Avatar
When I get some time, I plan on making a tubular torque arm out of rigid black wall tubing. From what my dad was saying, this stuff is quite a bit stronger than standard tubing due to the fact that it has a thick sidewall and is seamless. I'm gonna try and fab up a solid chassis mount for it as well.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
Ragtop Man
Sep 12, 2015 12:23 AM
